Kinivo WID380 Wireless Enhanced USB Adapter
USB adapter adds Wi-Fi capability to your computer and boosts connectivity speed, signal and reliability
Kinivo just announced the WID380 Wireless Enhanced USB Adapter, an all-in-one solution for enhancing existing Wi-Fi capabilities or adding wireless Internet to your desktop or later laptop models. Kinivo’s WID380 Wireless Enhanced USB Adapter adds dimension, increases speed, improves signal strength and heightens overall wireless Internet performance, establishing a more reliable network between your Internet router and laptop or desktop. The new WID380 delivers your device’s best wireless connection, maximizing performance and providing your signal a boost with speeds up to 300 Mbps for immediate high-speed wireless connectivity at home, work or hotspot locations.
The WID380 is the ultimate Wi-Fi solution for difficult-to-wire environments, including buildings with solid or finished walls, bringing the freedom of wireless Internet wherever you need. Mobile professionals and students will also benefit from Kinivo’s new WID380 given their frequently changing environments, requiring a reliable Internet connection between meetings, classes and more.
Kinivo’s user friendly WID380 connects by plugging directly into your laptop or desktop’s USB port, or, can be placed up to three feet away with the included extension cable. This optimal position allows the wireless dual antennas improve speed, range and signal strength. Helpful for mobile professionals, online gaming, digital media streaming and file transfer, Kinivo’s WID380 increases your Internet connection’s wireless capabilities to ensure they’re operating as efficiently and securely as possible.
Kinivo WID380
WID380 Technical Specifications
  • Supports wireless speeds up to 300 Mbps with 802.11n and channel bonding enabled wireless access points
  • R2 x 2dBi dual antennas enhance wireless experience by improving wireless signal strength and range
  • Compatible with all 802.11g/b/n 2.4GHz wireless networks
  • Security encryption using WEP, WPA and WPA2 (TKIP+AES)
Note: The WID380 does not operate in the 5GHz frequency with dual band routers.
Device Compatibility
  • WID380 transforms any computer with a USB port to a wireless capable computer
  • Supports IEEE 802.11n wireless N networks
  • Compatible with Windows 8.1 / 8 / 7
  • Wireless Protected Setup (WPS) for easy setup with WPS capable routers
  • Backwards compatible with 802.11b and 802.11g wireless networks
Price and Availability
The Kinivo WID380 is now available for $19.99 at Amazon.com.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
