Kinivo M2 Bluetooth 2.1 Speaker System
Kinivo M2 Speakers
Kinivo is now offering the M2 Bluetooth and NFC enabled 2.1 wireless speaker system for just $60. It can be used as PC / Mac speaker system or connect up to a TV. The 56-watt system contains two compact, sleek speakers with copper accents along with a craft wood subwoofer. The active subwoofer can be discreetly hidden and controlled remotely.
The company says M2 easily connects to your home entertainment system or computer, requiring no complicated set-up, wire routing or cable clutter, and delivers rich, crisp sound from the audio source. Wirelessly stream from any Bluetooth-enabled mobile device, allowing audio from your smartphone or tablet to instantly fill the room, or plug into the speakers directly through the auxiliary input.
“Whether you’re hosting a dinner party or want to freshen up your workspace this season, the M2’s sleek design makes it easy to add stylish audio to any room,” says Kinivo Director of Product Management Henry Wong. “Our spring deal gives listeners twice the sound for half the price.”
Price and Availability
The Kinivo M2 entertainment system is now available for $59.99 at Amazon.com ($120 MSRP) now through the end of April 2015.
M2 Technical Specifications
  • Supports Bluetooth protocol; A2DP audio streaming profile
  • Output power: 14 W x 2 + 28 W (RMS)
  • Power supply: 120 V, 60 Hz, 0.6A
  • Speakers: 3 (including subwoofer)
  • Impedance
    • Satellite Speaker: 4 ohms
    • Subwoofer: 8 ohms
  • Frequency Response
    • Satellite: 250-20 kHz
    • Subwoofer 30-100 Hz
  • S/N Ratio: 70 dB
  • Separation:  40 dB
  • Dimensions
    • Satellite Speaker: 5.5” x 5.4’’ x 5.2’’ (W D H)
  • Subwoofer: 8.6’’ x 9.5’’ x 9.0’’ (W D H)
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
