E-Readers
Kingston MobileLiteG2 Flash Card Reader
MobileLite Generation Two Multifunctional Flash Card Reader Makes Digital Data Transfer Easy
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced the release of the MobileLiteG2 card reader. The MobileLiteG2 is the second generation of the popular MobileLite Flash card reader, which allows easy data transfer between Flash memory cards and PC or Mac. Supported card formats include SD, SDHC, microSD, microSDHC, *Memory Stick PRO Duo™, *Memory Stick PRO-HG Duo™ and *Memory Stick Micro™ (*M2).
“The MobileLiteG2 is a small, portable reader that makes managing content quick and convenient between a device like a mobile phone, digital camera or MP3 player, and a host device with a USB connection such as a PC,” said Wendy Lecot, Flash card business manager, Kingston. “For consumers and business users, the compact size and simple plug-and-play ability makes it an essential part of one’s mobile gear.”
The MobileLiteG2 has retractable covers on each side to protect the USB connector and the Flash memory cards from damage. It ships with a lanyard and short USB extension cable to make it easier to use with harder-to-reach USB slots. When in use, the MobileLiteG2 appears as two drive letters (e.g., E:, F:). Data transfer between cards or host device is as simple as drag and drop.
The MobileLiteG2 ships as a stand-alone reader and is also available as a bundle with a 4GB or 8GB Class 4 SDHC card. The MobileLiteG2 is backed by a two-year warranty while Kingston cards carry a lifetime warranty.
MobileLiteG2 Features and Specifications:
  • Compliant: with the USB 2.0 specification, SD 2.00, SDHC 4.1 standard, new *MS PRO-HG Duo™ standard
  • Versatile: multi-functional USB card reader supports SD/SDHC, microSD/SDHC, *MSPD™, *MS PRO-HG Duo™ and *M2
  • Portable: easily fits into your pocket
  • Easy: plug and play into any USB 2.0 or 1.1 port
  • Dimensions: 2.45″ x 1.16″ x 0.646″ (62.15mm x 29.40mm x 16.40mm)
  • Weight: 18.90g
  • Operating Temperature: -40°F to 140°F (-40°C to 60°C)
  • Storage Temperature: -4°F to 158°F (-20°C to 70°C)
  • Guaranteed: two-year warranty
Compatibility Table
Operating System File Transfer
Windows 7 Yes
Windows Vista (SP1, SP2) Yes
Windows XP (SP1, SP2, SP3) Yes
Windows 2000 (SP4) Yes
Mac OS X v.10.3.x+ Yes
Linux v.2.6.x + Yes
Part Number Capacity and Features MSRP (U.S. only)
FCR-MLG2 MobileLiteG2 Flash Card Reader $11.00
FCR-MLG2+SD4/4GB MobileLiteG2 + 4GB Class 4 SDHC $28.50
FCR-MLG2+SD4/8GB MobileLiteG2 + 8GB Class 4 SDHC $46.00
Bang & Olufsen Beosound Balance Natura Wireless Speakers
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Advance Paris Link Cables Advance Paris Link Cables
Audio Cables
High-end cables made in France? Do British and American manufacturers need to be concerned? The Advance Paris LINK have us excited to try them.
https://www.audioadvice.com/products/kaleidescape-strato-c-4k-ultra-hd-movie-player?referral=ecoustics Strato M Movie Player https://www.audioadvice.com/products/kaleidescape-strato-c-4k-ultra-hd-movie-player?referral=ecoustics Strato M Movie Player
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a big catch to take into consideration.
Sony's new 2025 model year BRAVIA TVs Sony's new 2025 model year BRAVIA TVs
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
Sony BTAVIA Projectors - 2025 Sony BTAVIA Projectors - 2025
Sony just brought its most powerful video processor for projectors down to what should be a much more affordable price point.
Sony BRAVIA Theater fill lineup - 2025. Sony BRAVIA Theater fill lineup - 2025.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
