Plug and Play Memory Uses JEDEC-compliant 1600MHz, 1866MHz Values Compatible with Faster Sandy Bridge Ready Frequencies
Kingston announced the HyperX Plug and Play (PnP) series of high-performance enthusiast memory. HyperX PnP are the first modules to scale the higher memory heights that are a part of the second generation Intel Core i5 and i7 CPUs. The memory is programmed with faster frequencies and when 'plugged' into a system using the Sandy Bridge chipset, will automatically 'play' at either 1600MHz or 1866MHz in both desktop and notebook PCs.
The modules are programmed using JEDEC-compliant settings, allowing 1600MHz and 1866MHz frequency support. It is as simple as plugging in the memory and turning on the machine, as the system automatically recognizes faster memory speed with no further BIOS settings required. Users will notice performance gains as overclocking is automatic with the HyperX Plug and Play modules. In addition, the modules are backwards compatible with previously released DDR3 systems on the market.
“The HyperX engineering team has been thoroughly innovative in designing a memory module that automatically raises performance with no overclocking steps required,” said Mark Tekunoff, senior technology manager, Kingston. “By using JEDEC-compliant settings to create performance timings, enthusiasts can max out native frequencies on current Sandy Bridge systems and older DDR3 machines.”
Kingston HyperX Plug and Play DDR3 1600MHz, 1866MHz Specifications
Part Number | Capacity and Features | MSRP (U.S. only) | |
KHX1600C9D3P1K2/8G | 8GB 1600MHz Non-ECC DIMM @ 1.5v (kit of 2) CL9-9-9 HyperX Plug and Play | $122.00 | |
KHX1600C9D3P1K2/4G | 4GB 1600MHz Non-ECC DIMM @ 1.5v (kit of 2) CL9-9-9 HyperX Plug and Play | $67.00 | |
KHX1600C9S3P1K2/8G | 8GB 1600MHz Non-ECC SODIMM @ 1.5v (kit of 2) CL9-9-9 HyperX Plug and Play | $122.00 | |
KHX1600C9S3P1K2/4G | 4GB 1600MHz Non-ECC SODIMM @ 1.5v (kit of 2) CL9-9-9 HyperX Plug and Play | $67.00 | |
KHX1866C11S3P1K2/8G | 8GB 1866MHz Non-ECC SODIMM @ 1.5v (kit of 2) CL11-11-11 HyperX Plug and Play | $163.00 | |
KHX1866C11S3P1K2/4G | 4GB 1866MHz Non-ECC SODIMM @ 1.5v (kit of 2) CL11-11-11 HyperX Plug and Play | $88.00 |
