The Kii SEVEN Wireless Music System Offers a Compelling Reason to Drop Separates
Move over Sonos. Kii Seven is a bleeding edge wireless speaker that can be linked together for stereo listening, home theater or multi-room.
Kii SEVEN Wireless Speaker in Fine Touch White Angle
Building upon the success of the Kii THREE, Kii Audio is introducing the Kii SEVEN Wireless Music System at the UK Hi-Fi Show Live (Sept 29th through Oct 1st). Whilst the system will not start shipping until Q1 2024, there is already a lot of interest in this natural rival to KEF’s lineup of active wireless loudspeakers including the LS60 and LS50 Wireless II.
Since 2015, Kii Audio has dedicated itself to delivering innovation, quality, and the ultimate user experience with their products.
The new Kii SEVEN Wireless Music System continues that emphasis by combining high-quality audio with intuitive smart functionality.
Kii SEVEN Wireless Speaker Fine Touch White Pair
Overview
The Kii SEVEN can be used with just one speaker (Solo), a two-speaker system (Stereo Pair), a part of a multi-speaker surround system (including Dolby Atmos), or part of a multiroom system like Sonos.
Unlike many smart speakers, the Kii SEVEN has been designed by Kii Audio’s engineers as a Cardioid Speaker, thereby significantly reducing the impact of room acoustics.
Using Active Wave Focusing, the Kii SEVEN is designed to deliver detailed separation and excellent musicality; audiophile-grade audio that more accurately captures the essence of reproduced music.
Kii SEVEN Wireless Speaker Onboard Controls
Instead of splitting audio frequencies into bands as is done with traditional crossover filters, Kii Audio’s Active Wave Focusing filters force the specially positioned drive units in the Kii SEVEN to create a coherent wave front, that is only emitted towards the listener. This ensures perfect time alignment over the full frequency spectrum.
The Kii SEVEN produces a Cardioid Sound Dispersion pattern down to the low-mid and bass frequencies, providing even and more precise bass, as well as significantly limiting acoustic room interaction.
Kii Home App
Kii Home App
Seamlessly integrating with mobile devices, the Kii SEVEN makes it incredibly easy to access a range of useful features. From streaming playlists to controlling playback in multiple rooms, the Kii SEVEN has been designed to marry convenience with cutting-edge technology. Thanks to the versatile Kii HOME App (iOS, Android) whether you have one Kii SEVEN or a dozen, you are able to easily customize acoustic settings for up to twelve separate zones in your home.
Specifications
  • Woofer: 2 x 6.5-inch Active Wave-Focused Woofers
  • Midrange: 1 x 5-inch Midrange
  • Tweeter: 1 x 1-inch Custom Wave-guided Tweeter
  • Amplification: 600 Watts
  • Crossover Type: Active Wave Focusing Crossover filter – Cardioid Dispersion
  • Frequency Response: 40Hz (-3dB), 100Hz-10kH: (+/- 0.5dB), 10kHz – 20kHz (+/- 1dB)
  • Integrated Tone Control: Adjust bass and treble levels to match your listening taste.
  • Phase Response: Minimum Phase or Minimum Latency
  • Driver Protection Limiters: Protects driver elements from damage if required.
  • Wired Inputs: XLR and TRS, AES/EBU, DANTEKiiLink/KiiCONTROL
  • Wireless Inputs: WiFi, Bluetooth,
  • Streaming Support: Airplay 2, Spotify Connection, Tidal Connect, Qobuz Connect
  • Roon Ready: Yes
  • Hi-Res Audio Support: ≤ 24-bit / 192kHz
  • Finish/Colors: Fine Touch White / Fine Touch Dark Grey
  • Dimensions (WxHxD): 20 x 31 x 31 cm  (8 x 12.2 x 12.2-inches)
  • Weight: 14kg (30lbs)
Kii SEVEN Wireless Speaker Fine Touch Dark Grey Angle
Availability and Pricing
The Kii Audio Kii SEVEN will be available in early 2024, priced at:
  • Single speaker: $3,895 / €3,795 / £3,495
  • Stereo pair: $7,790 / €7,590 / £6,990
Tip: Kii Audio will be showcasing the Kii SEVEN at the UK Hi-Fi Show Live (Room 260/261) at Ascot Racecourse from 29th September – October 1st.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
