Keyboards
KeyScan KS810-Plus Imaging Keyboard / Scanner
KeyScan combines the power of a quick color scanner with keyboard for easy scanning of documents, photos, plastic cards, driver’s licenses and more
KeyScan, the first exclusive inventor and developer of the integrated keyboard-scanner product and of the “NoTouch™-AutoScan” software, unveils the KS810-Plus Imaging Keyboard. This new and unique category of keyboard is a must have tool for any office or work area, the KS810-P delivers full A4 size page gray scanning in a quick 5 seconds making difficult scanning tasks easy. With 15 preset functions for non-default jobs, this imaging keyboard makes saving and emailing documents and photos effortless. The unique “NoTouch™-AutoScan” software allows the user to complete their most frequent scanning task without touching any button, simply place the document on the feeding tray. This new multi function peripheral (MFP) keyboard solution also features a USB2 Hub with only single USB connected to the PC both for the HUB the keyboard and the built-in scanner and two downstream ports for other low to high speed devices. KS810-P is available for $139.99 at TigerDirect.com, CompUSA and KeyScan.com
“Our new imaging keyboard puts the power of color scanning at your fingertips saving you space and changing your office into a paperless environmentally friendly workplace” says Dov Aharonson, CEO of KeyScan . “We are happy to provide a fast high quality imaging solution that will provide convenient emailing, archiving and copying solutions right from your keyboard.”
The KS810-P is a fast USB2 sheet feed imaging keyboard that provides a multitude of features and scanning capabilities including:
  • KeyScan “No Touch” scanning software
  • Capable of scanning documents ranging in size from 2×3″ to 8.5×30″ including plastic cards and drivers licenses that are 3.5×2.5″ up to 1mm thick
  • Scans letter size, 300dpi gray in 5 seconds and color documents or photos in 15 seconds
  • A 600dpi high optical resolution
  • A 50dpi to 4800dpi output resolution
  • Converts scanned documents into a variety of file formats: PDF, MS-Word, HTML, JPG, TIFF, BMP
  • Allows you to email scans as attachments or fax* them directly from your computer
  • Secure email files with password
  • Document release is bi-directional based on the document length
  • Integrated USB2 Hub
  • High quality keyboard with 6 dedicated internet access buttons and 4 scan buttons
  • Minimum system requirements are Windows, XPS-SP2 or higher, Vista both 32/64 bits, Microsoft Net 2.0 or higher, 1GB RAM, 1GB free hard disk
* Fax and copier functions require access to fax-modem and printer. May require 3rd party software.
About KeyScan:
KeyScan is an innovative developer of unique, highly efficient, personal interactive, productivity and communication scanning hardware and software tools. KeyScan provides the easiest way to capture documents, photographs and more directly to many Window applications, document imaging applications and to KeyScan Imaging Software. KeyScan is the original exclusive inventor and developer of the integrated keyboard-scanner product and of its distinctive software including the “NoTouch™-AutoScan” software.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
