iPad Apps
Kensington PowerBack Battery Case with Kickstand and Dock for iPad
The Kensington PowerBack Battery Case with Kickstand and Dock slips over the back of your iPad to provide power, protection and a convenient prop. With up to 5 extra hours of power, you'll have plenty of juice for app use, web surfing, and movie watching. The 3-position steel kickstand even holds your iPad handsfree in typing, portrait, or landscape modes.
Features
  • Built-in 4400mAh battery provides up to 5 extra hours of power Micro USB charge and sync port lets you charge and sync without removing the PowerBack
  • Built-in speaker deflectors for clear, crisp sound
  • LED battery fuel gauge indicates charge amount
  • Soft touch finish case protects your iPad from bumps and bruises
Price and Availability
Kensington PowerBack Battery Case with Kickstand and Dock (K39249US; SRP $129.99) will be available October 1, 2010.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
