KEF X300A Powered Speakers
KEF X300A Speaker
KEF announced the audiophile-grade X300A digital hi-fi speaker system designed to partner with a PC or Mac, desktop or laptop computer. Simply connect the speakers via a ‘distortion free’ USB all-digital link to provide high resolution 96kHz/24 bit quality digital input and inter-speaker connection to ensure high definition sound from source to output. Each speaker features twin class AB audiophile grade amplifiers inside, one for HF and one for LF/MF.
KEF X300A - inside
Unlike typical powered speaker designs, each X300A speaker utilizes two Class AB audiophile-grade amplifiers as well as two DAC’s (one in each speaker) so as to deliver accurate, high resolution playback.
The X300A offers high resolution inputs and inter-speaker connections to ensure lossless high resolution sound from source to output. The KEF Engineers designed X300A to by-pass the computers internal DAC to make use of the audiophile grade DAC in each X300A speaker!
KEF X300A Speakers with Mac
Users can also connect an Apple iPod, iPhone iPad, Android, Kindle Fire or any other digital device direct to the system via analog input.
To get the very best from the four total Class AB amplifiers, an award-winning Uni-Q driver design adapted from KEF’s flagship Blade speaker is featured in the X300A.
[youtube id=”nRnFvMTlgdY” width=”610″ height=”373″]
Specifications:
  • Two-way bass reflex bookshelf loudspeaker
  • Drive Units: 5.25in. Uni-Q, 1in. aluminium dome HF
  • Frequency Response (+/- 3db): 58Hz – 28KHz
  • Frequency Range (+/- 6db): 49Hz – 45KHz
  • Max SPL: 104db
  • Amplifier type/class: Bi-Amped Class AB amp
  • AC Power Outputs: 100-120VAC, 50/60Hz
  • Power Output: 150W per channel @ 1kHz
  • Input Impedance: AUX 47K ohms
  • Analog Input: 3.5mm stereo jack
  • Digital Input: USB: Mini USB type B connector
  • Controls: Balance Control, AUX Control
  • Accessories: power cord x 2, USB x 2, Bluetooth adapter x 1 (Shipped separately upon product registration) 3.5mm stereo wire x 1
  • Resolution: Up to 24-bit
  • Sampling Rate: Up to 96 kHz (depending on source resolution)
  • Internal Volume: 47L
  • Dimensions: 11.1 x 7.1 x 9.6 in., Weight: 16.5 lbs. each
  • Finishes Available: Gun Metal
KEF X300A Speakers - Pair
Price and Availability
The KEF X300A Digital Hi-Fi Speaker System will be available mid-January 2013 for $799.99 in gunmetal finish. Pre-order now at kefdirect.com.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
As Black Friday 2024 approaches, Amazon and KEF are teaming up with big discounts on some of the company's best loudspeakers.
Priced from $600 to $2,200 per pair, KEF's most affordable loudspeaker range includes 8 models featuring 12th generation Uni-Q drivers.
Daily Deals
KEF has permanently lowered pricing across its range of wireless speakers, including LSX II, LS50 Wireless II and LS60 Wireless loudspeakers.
Some of KEF's most popular loudspeakers are on sale while supplies last until August 31, 2024.
In-Wall Speakers
Music in the bedroom? Savoir and KEF have teamed up to introduce the world's first ultra luxury speaker bed.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
A little splash of color for the KEF LSX II Wireless Speakers? Olive green joins the list of available finish options.
