In-Wall Speakers
KEF Adds Two THX Certified In-wall Speakers to its Ci-R Series
KEF’s Extreme Home Theatre Range adds two slightly more affordable in-wall LCR models with THX Ultra Certification.
KEF Ci3160RLM-THX In-wall Speakers Lifestyle living room
Architectural (in-wall/in-ceiling) loudspeakers were already gaining popularity before the pandemic, but all of that changed when tens of millions of families were forced to work and learn from home. With movie theaters, stadiums, and live music venues shuttered for over a year in some parts of North America, consumers started to rethink their long-term home entertainment goals and part of that included a significant surge in demand for these types of loudspeakers.
The CI loudspeaker category has become a key focus for high-end brands like Monitor Audio, MartinLogan, Focal, Dynaudio, DALI and KEF.
Why? It’s an easier sell because you don’t have to see them and that includes cables and often components that are installed in racks.
Outdoor and marine loudspeakers have also become a focus for brands like Focal and KEF as wealthier consumers tend to invest in multi-room systems and boats.
For those with really deep pockets, KEF’s Extreme Ci-Reference Series is designed to deliver the best possible sound quality and installation experience for consumers looking for a high-end in-wall solution.
KEF’s Extreme Home Theater Category offers up three speaker series, the Ci-Reference, Ci-Q, and Ci-R.
KEF Ci-R Series
In this article, we discuss the newly announced models in the Ci-R series; the Ci5160RLM-THX and Ci3160RLM-THX.
KEF Ci3160RLM-THX
The Ci-R Series builds on the acoustic capabilities derived from KEF’s flagship Reference bookshelf and floorstanding speakers, combined with additional technological innovations developed for in-wall and in-ceiling use.
KEF Ci5160RLM-THX In-wall Speaker
KEF Ci5160RLM-THX
THX Certification
Just as with all speakers in the KEF’s Extreme Home Theater category, the Ci5160RLM and Ci3160RLM are THX Certified, in this case with Ultra certification. THX Ultra Certification means that the speaker is optimized for rooms up to 3,000 cubic feet and a 12-foot viewing distance from the screen.
THX Certified Performance Classes
THX Certification Process
Three additional things that THX tests for when evaluating speakers include:
  • Axial Frequency Response – This is the ability to reproduce audio accurately. THX confirms the axial frequency response is balanced and flat.
  • Output vs Distortion:– This tests whether the speaker can produce the high volume necessary to achieve the THX Reference Level without creating audible distortion or artifacts.
  • Vertical and Horizontal Dispersion: – THX tests off-axis response to make sure it is smooth with no audible comb filtering, making every seat in the room the sweet spot.
Ci5160RLM-THX and Ci3160RLM-THX Core Features
Metamaterial Absorption Technology (MAT): This removes 99% of high-frequency distortion for pure, natural sound.
12th generation Uni-Q (with MAT) driver array: This supports precise acoustic accuracy.
Aluminum Bass Drivers: Four (Ci5160RLM-THX) or Two (Ci3160RLM-THX)  hybrid aluminum bass drivers for tight, deep, controlled bass
Discreet Design: This provides easy blending into the room
Finish: Available in Aluminium Silver
Paintable Magnetic Metal Grille: This provides additional installation flexibility for any interior. Optional black cloth grille also available
KEF Ci15160RLM and
Ci13160RLM THX In-wall Speakers
Comparison
Ci5160RLM-THXCi3160RLM-THX
MSRP (each)$2,999.99$1,999.99
SeriesCi-R Ci-R
THX CertificationUltraUltra
Speaker Configuration 3-way3-way
Nominal Impedance4 ohms4 ohms
Sensitivity (2.83V/1m)89dB89dB
Frequency Response (±6dB) open-backed40Hz to 28kHz43Hz – 28kHz
Frequency Range (-10dB)32Hz – 45kHz33Hz – 45kHz
Nominal Coverage (degrees)150°150°
Max SPL (dB)110dB110dB
Crossover Frequency640Hz, 2.6kHz640Hz, 2.6kHz
Low-Frequency Driver4 x 160mm (6.5in.)2 x 160mm (6.5in.)
Mid-Frequency Driver (Uni-Q)1 x 160mm (6.5in.) 1 x 160mm (6.5in.)
High-Frequency Driver (vented aluminum dome with MAT)1 x 25mm (1in.) 1 x 25mm (1in.)
Recommended Amplifier Power50 – 350W50 – 350W
Recommended High-Pass filter35 – 80Hz35 – 80Hz
External Dimensions (HWD)1070 x 230 x 105.7 mm (42.13 x 9.06 x 4.16 in.)680 x 230 x 105.7mm(26.77 x 9.06 x 4.16in.)
Cut-Out Dimensions (HW)1052 x 209 mm (41.42 x 8.23 in.)660 x 209mm (25.98 x 8.23in.)
Net Weight18.7 kg (41.1 lbs.)12 kg (26.4 lbs.)
Mounting Depth From Surface99mm (3.9in.)99mm (3.9in.)
Optional Rough-in-FrameRIF5160LRIF3160L
Ideal Rear Volume (Liters)90L60L
Minimum Rear Volume (Liters)40L30L
Wall Thickness (Maximum)40mm (1.58in.)40mm (1.58in.)
Wall Thickness (Minimum)6mm (0.24in.)6mm (0.24in.)
Pricing and Availability
Available now through KEF Authorized Dealers at the following prices:
  • KEF Ci5160RLM-THX are priced at $2,999.99 each
  • KEF Ci3160RLM-THX are priced at $1,999.99 each
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Audio Cables
At £10 per/meter, the Chord Company Leyline2XL are 14 AWG speaker cables designed for custom installers that require long cable runs.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
As Black Friday 2024 approaches, Amazon and KEF are teaming up with big discounts on some of the company's best loudspeakers.
Priced from $600 to $2,200 per pair, KEF's most affordable loudspeaker range includes 8 models featuring 12th generation Uni-Q drivers.
Arendal's flagship loudspeaker series are THX Ultra Certified for large home theater speaker system configurations.
