In-Wall Speakers
KEF’s THX Dominus In-Wall Speakers Deliver High-End Performance At A Lofty Price
KEF implements latest Uni-Q drivers in new flagship architectural speaker line. There are two new models that are THX Domimus and THX Ultra Certified for home theater.
KEF Ci5160REFM-THX and Ci3160REFM-THX in-wall home theater speaker system lifestyle
KEF first introduced its 12th generation Uni-Q driver array with Metamaterial Absorption Technology (MAT) in the LS50 Meta Bookshelf Loudspeakers in 2020. Since then KEF’s innovative coaxial driver has been making its way through their speaker line-up, which includes Blade and ReferenceLS60, Ci250RRM-THX, and R Meta Series.
KEF’s flagship architectural speakers from its Ci-Reference Extreme Series have been updated with 12th generation technology. The new Ci5160REFM-THX and Ci3160REFM-THX in-wall speakers have arrived at a rather steep price; $11K and $8K each, respectively. They replace the Ci5160REF-THX and Ci3160REF-THX, which have almost the same model name, but without the “M”.
Tip: Metamaterial Absorption Technology (MAT) claims to deliver more natural sounding treble.
THX Certification
Just as with its previously announced in-wall Ci250RRM speaker and Ci250RRb in-wall Subwoofer, the new architectural speakers are also THX Certified with the Ci5160REFM carrying the THX Dominus and the Ci3160REFM carrying the THX Ultra designations.
THX Certified Performance Classes
THX Certification Process
  • THX Dominus Certification means that the speaker is optimized for rooms as large as 6,500 cubic feet, and up to a 20-foot viewing distance from the screen.
  • THX Ultra Certification means that the speaker is optimized for rooms up to 3,000 cubic feet and a 12-foot viewing distance from the screen.
Common Features
KEF Ci5160REFM-THX 12th Generation Uni-Q Driver with MAT
Both new models use KEF’s 12th Generation Uni-Q Driver with MAT.
To provide optimal sound quality, these two speakers also incorporate the following KEF Technologies and Features.
  • Paintable Magnetic Grill: More than just being decorative, the provided grills provide a balance between driver protection, sonic performance, and aesthetics. Optional cloth grill available.
  • Impedance: The speakers have a 4-ohm impedance.
  • Finish: Aluminum Black/Grey.
Tip: Both speakers can be used vertically as left, right, or surround speakers, or horizontally as a center channel speaker.
Ci5160REFM-THX
KEF Ci5160REFM-THX In-Wall Speaker
KEF Ci5160REFM-THX
In addition to the features listed above, The Ci5160REFM-THX is KEF’s first THX Dominus Certified in-wall speaker. This speaker incorporates four 6.5-inch bass drivers for optimized bass performance for in-wall setups. The speaker also features an 11mm thick machined aluminum baffle to limit unwanted vibration.
Ci3160REFM-THX
KEF Ci3160REFM-THX In-Wall Speaker
KEF Ci3160REFM-THX
As mentioned previously, the  Ci3160REFM-THX in-wall speaker is THX Ultra Certified. It is more compact than the Ci5160REFM-THX as it incorporates two 6.5-inch bass drivers rather than four for bass performance. KEF does not mention if this speaker also includes an 11mm thick baffle.
Comparison
Speaker ModelCi5160REFM-THXCi3160REFM-THX
MSRP$10,999 each$7,999 each
SeriesCi-Reference Ci-Reference
THX CertificationTHX DominusTHX Ultra
Speaker Configuration3-way3-way
Nominal Impedance4 ohms4 ohms
Sensitivity (2.83V/1m)92dB89dB
Frequency Response (+/- 6dB) Open-back40Hz to 28kHz40Hz to 28kHz
Frequency Range (-10 dB)32Hz to 45Hz32Hz to 45Hz
Nominal Coverage 150 degrees150 degrees
MAX SPL (dB)116 dB110 dB
Crossover Frequency600Hz, 3kHz600Hz, 3kHz
LF Driver4 x 160mm (6.5 inches)2 x 160mm (6.5 inches)
MF Driver (Uni-Q)1 x 125 mm (5.25-inches)1 x 125 mm (5.25-inches)
HF Driver (Vented Aluminum Dome Tweeter with MAT)1 x 25mm (1-inch)1 x 25mm (1-inch)
Recommended Amp Power50 to 500 watts50 to 350 watts
Recommend Hi-Pass Filter35 to 80Hz35 to 80Hz
External Dimensions (HWD)1070 x 230 x 105.7 mm (42.13 x 9.06 x 4.16-inches)680 x 230 x 105.7 mm(26.77 x 9.06 x 4.16 inches)
Cutout Dimensions  (HW)1052 x 209 mm (41.42 x 8.23-inches)660 x 209 mm (25.98 x 8.23 inches)
Net Weight 21.7 kg (47.8 lbs)13.6 kg (29.92 lbs)
Mounting Depth From Surface99 mm (3.9 inches)99 mm (3.9 inches)
Optional Rough in FrameRIF5160LRIF3160L
Ideal Rear Volume90 Liters60 Liters
Maximum Rear Volume40 Liters30 Liters
Wall Thickness Maximum40 mm (1.58-inches)40 mm (1.58-inches)
Wall Thickness Minimum6mm (0.24 inches)6mm (0.24 inches)
KEF Ci5160REFM-THX and Ci3160REFM-THX in-wall LCR speaker system lifestyle
KEF Ci5160REFM-THX In-Wall Speakers (Left/Right) with KEF Ci3160REFM-THX (Center)
Competition
KEF isn’t the only company with a THX Dominus Certified In-Wall Speaker. Perlisten has 8 architectural speakers that are THX Dominus Certified. Although, Focal doesn’t offer THX certification, their flagship 1000 Series In-Wall Speakers with Beryllium tweeters are sure to please a lot of audiophiles.
Related Reading: Theory Audio Design 5.2.2 Surround Sound System Review
Prices & Availability
  • The KEF Ci5160REFM-THX is priced $10,999.99 each
  • The KEF Ci3160REFM-THX is priced $7,999.99 each.
For more information: us.kef.com
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
KEF adds two new colors to its LSX II wireless speakers, refreshing the compact hi-fi lineup — but in a price-sensitive market, is a...
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
In-Wall Speakers
KEF expands its Extreme Home Theater line with the THX-Certified Ci5120QLM-THX and Ci3120QLM-THX in-wall speakers, priced at $1,699.99 and $1,299.99 each.
KEF refreshes its flagship Blade Meta speakers for 2025 with three new color options—Grigio, Garnet, and Sapphire—while retiring older finishes. Same legendary sound, bold...
KEF Muo ($249.99) arrives Sept 23 for myKEF, full launch Sept 30—Bluetooth 5.4, aptX Adaptive, IP67, 24hr battery, and P-Flex racetrack driver.
In-Wall Speakers
Theory Audio Design shows that you can put together a fine-sounding home theater system - or whole home music system - for a whole...
