KEF Unveil Updated Blade and The Reference Loudspeakers
The KEF Blade and The Reference Speaker Series have been updated with its 12th generation Uni-Q with MAT technology.
KEF Blade and Reference Loudspeakers
KEF have not updated The Reference or Blade loudspeakers for a number of years but all of that is changing in 2022. The KEF Blade has definitely made more than a few appearances over the past five years at Hi-Fi events around the globe and its striking industrial design isn’t just for show.
The two high-end KEF speaker ranges have been updated with KEF’s latest acoustic innovations, including a new, high-end 12th generation Uni-Q with Metamaterial Absorption Technology (MAT™).
Priced from $9,000 to $35,000 a pair, customers with deep pockets may be drawn to KEF’s new lines for their unique style and color options in addition to their sound quality. Others competing in the five figure ballpark include Theory Audio’s On-Wall Speaker System and well as the PS Audio aspen FR30, among many more.
The Reference Series are designed for both 2-channel and home theater systems; two of the 4 models can be used in a LCR scenario.
KEF Blade Meta Charcoal Grey Bronze
KEF Blade 1 Meta and Blade 2 Meta Loudspeakers
Both the Blade and The Reference are still hand-assembled in Maidstone, England, with each pair assembled by an individual master craftsmen. Each pair is then tested to match within 0.5dB of each other and the laboratory-maintained line standard, ensuring that what leaves the factory matches what KEF’s engineers have designed.
The LSX and LS50 models are manufactured and assembled in China which enables KEF to keep both loudspeaker ranges affordable.
Revolutionary Technology
KEFs latest entry in the 12th Generation of Uni-Q is a ground-up design including a new approach to decoupling, and a state-of-the-art motor system.
For both series, the crossover has been fully reworked with new, low distortion components with an eye to ensuring signal integrity. With Blade, further work has been carried out to enhance the benefits of Single Apparent Source, the defining technology of this unique range.
Blade
KEF Blade 1 Meta Loudspeakers Pair in Racing Red with Silver
KEF Blade 1 Meta (Racing Red/Silver)
KEF Blade 2 Meta Loudspeakers in Arctic White and Champagne
KEF Blade 2 Meta (Arctic White/Champagne)
At the heart of Blade lies the Single Apparent Source technology.This technology expands the benefits of Uni-Q across all frequencies by closely following the acoustic ideal of a point source. This makes Blade incredibly coherent across all audible frequencies.
Another key to Blade’s clean sound signature is also thanks to Single Apparent Source. The positioning of the bass drivers allows them to be braced against each other, cancelling out damaging vibrations that would excite the cabinet.
Blade’s sculptural design is informed by both technology and acoustics. The gentle front radius tapers gracefully from top to bottom and from front to rear, and presents no discontinuity to mar sound clarity.
The Reference
KEF Reference 1 Meta Stand-mount Loudspeakers Black Copper with stands Bookshelf Loudspeakers
KEF Reference 1 Meta Stand-mount Loudspeakers (Special Order in High Gloss Black/ Copper)
The Reference boasts a massive, vented magnet assembly paired with a huge aluminum voice coil and a stiff, damped alloy cone ensures The Reference is fully capable of achieving pipe-organ low end response and dynamics.
Whilst a more traditional outward form, The Reference is anything but. The rectilinear cabinet design hides several features – many pioneered by KEF.
Surrounding the 12th Generation Uni-Q sits Shadow Flare – a specially profiled trim ring that reduces the negative effects of diffraction, allowing Uni-Q to deliver a beautifully wide and accurate soundstage. Constrained Layer Damping and tuned internal chambering tackles the issues of vibration and standing waves respectively.
The adjustable flexible ports reduces port resonances whilst also allowing for fine tuning based on where the speaker is placed in the listening room
Models and Finishes
The Blade range is headlined by the commanding Blade One, with Blade Two suited for smaller listening environments.
Both are available in four standard finishes (Piano Black / Grey, Arctic White / Champagne, Charcoal Grey / Bronze, Frosted Blue / Blue) and four special order finishes (Piano Black/ Copper, Frosted Blue/Bronze, Charcoal Grey/Red, Racing Red/Grey).
For those who really want to elevate their ownership of Blade, KEF will also be offering custom finishes, with orders starting in June 2022.
KEF Reference 3 Meta Loudspeakers in High Gloss White with Blue Special Order Pair
KEF Reference 3 Meta (Special Order with High Gloss White and Blue)
The Reference range caters for any requirement, with two floorstanding models (Reference 5, Reference 3), a standmount (Reference 1) and two LCR models (Reference 4, Reference 2).
KEF Reference 2 Meta LCR Loudspeaker Black Copper Center Speaker
KEF Reference 2 Meta LCR Speaker (Special Order High Gloss Black/Copper)
KEF Reference 4 Meta Satin Walnut Silver LCR Speaker
KEF Reference 4 Meta LCR Speaker (Satin Walnut and Silver)
The redesign of the Reference 2 and Reference 4 makes them ideal for use as LCR speakers, creating more possibilities for great sound for those with custom cabinetry or designing for a home theater
All will be available in three standard finishes (Satin Walnut/Silver, High-Gloss White Champagne, High-Gloss Black/Grey) and two special order finishes (High-Gloss White/Blue, High-Gloss Black/Copper).
KEF Reference 5 Meta in High Gloss Black with Copper Special Order Loudspeakers Pair Grille Off
KEF Reference 5 Meta (Special Order in High Gloss Black with Copper)
Price & Availability
Available June 2022.
  • Blade One Meta: $35,000 / pair
  • Blade Two Meta:  $28,000 / pair
  • Reference 5 Meta: $22,000 / pair
  • Reference 3 Meta: $15,000 / pair
  • Reference 1 Meta: $9,000 / pair
  • Reference 4 Meta: $8,000 / each
  • Reference 2 Meta: $6,000 / each
  • S-RF1 Floor Stand: $1,200 / pair
For more information: https://us.kef.com
Related reading: Amazon Music HD Streams Into KEF LS50 Wireless II Speakers
1 Comment
1 Comment
  1. GordM
    March 4, 2022 at 1:49 am
    I just recently purchased a pair of R3s, which series is all new as well, BTW. I plunked them down on top of my MartinLogan subs and recalibrated the ARC room correction and happiness ensued. I had walked past the KEFs on display at hi-fi boutiques for years until I finally decided to give the new R7s a listen one day and I was blown away. I balked a little at the $6,000.00 CAD price but the dealer rec’d that, since I had a pair of powered subs, that I should consider the R3s. He was not wrong. Last weekend I tested them with the subs disconnected for the first time and noted that the bottom end was actually quite impressive indeed for a small, passive loudspeaker.
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
Podcasts
Rune Skov, Gryphon Audio Designs' Global Sales Director joins us on the podcast from Denmark to discuss the brand's Nordic Noir ethos.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
