A/V Furniture & Accessories
Kanto Launches 3 Innovative TV Mounts For 40″ – 120″ Screen Sizes: CEDIA 2024
Need to wall mount an extra large display or looking for a swivel TV stand? Kanto has three unique solutions under $400.
Kanto R600 TV Mount over Fireplace Lifestyle
CEDIA 2024 is underway and you can follow all of our coverage here. Chris Boylan and Robert Silva are in Denver all week and will be reporting on the latest CI innovations and experiencing some of the best home theater systems currently available.
One of the biggest changes over the past few years has been the growth of the large TV market; we consider anything between 85 and 120 inches to fall into that category and there are some extremely impressive options available from Samsung, LG, TCL, and Hisense that we have already featured.
Whilst not everyone is in the market for such a large TV, the market is certainly pushing 65″ or larger and consumers still require a TV mount to make that work in a myriad of scenarios.
Kanto has launched three new solutions for mounting TV screens:
  • PMX800 Full Motion TV Wall Mount with Adjustable Offset for 55″ – 120″ TVs.
  • R600 Recessed In-wall Full Motion Articulating TV Mount for 65″ – 90″ TVs.
  • TTS140 Height Adjustable & Swiveling Tabletop TV Stand for 40″ – 90″ TVs.
Catering for a wide range of screen sizes (from 40″ – 120″), these new mounts offer both wall-mount and table-top solutions. Designed with ease of install, maximum compatibility, and versatility of screen position in mind, the new Kanto PMX800, R600 and TTS140 mounts sport innovative cable-management, are all VESA compatible, and fully adjustable.
Kanto PMX800
Kanto PMX800 TV Mount
Kanto PMX800 Full Motion TV Wall Mount with Adjustable Offset for 55″ – 120″ TVs
Capable of supporting panels up to 120”, the new Kanto PMX800 adjustable wall mount can be horizontally offset 11” in either direction to dial in the lateral placement of your display.
An oversized 900×600 VESA interface improves compatibility with extra-large touch screens and provides flexibility for vertical positioning. With 31.3” of extension, this full motion wall mount gives you all the swivel needed to get the perfect viewing angle.
Its low-profile design allows your TV to sit 2.6” from the wall when fully retracted and features all-metal cable management and lag bolt covers to stand the test of time. Tool-less tilt rounds off PMX800’s extensive feature set allowing for on-the-fly adjustments.
PMX800 Key Features:
  • EXTRA LARGE DISPLAYS – Whether you’re designing the ultimate home theatre, or installing interactive touch panels, PMX800’s 200 lbs. weight capacity ensures compatibility with displays of any size.
  • PERFECT PANEL PLACEMENT – Even if your studs are in a suboptimal position, you can still nail your TVs placement with 22 total inches of horizontal offset. Oversized TV brackets provide flexibility to achieve the perfect height.
  • FULLY ADJUSTABLE – A tool-less cam lever tilt mechanism allows for on-the-fly adjustments, while 31.3” of extension allows for generous amounts of swivel with even very large TVs.
  • LOW-PROFILE – Despite its impressive reach, PMX800 retracts to an impressive 2.6” giving thin TVs a flush look when pushed against the wall.
  • DESIGNED TO LAST – PMX800’s cable management system and lag bolt covers are made of metal to stand up to regular use and reduce potential service calls.
The Kanto PMX800 is $399.99 at Crutchfield
Kanto R600
Kanto R600 TV Mount over sofa
Kanto TTS140 Height Adjustable & Swiveling Tabletop TV Stand for 40″ – 90″ TVs
The new Kanto R600 features an oversized in-wall box that allows cable set-top boxes and TV breakout boxes to be stored in the wall on the included accessory plate.
Two TV mounting interfaces are provided – one with a no gap profile for TVs with small VESA patterns, and one with support for extra large panels. Metal knockouts allow you to easily run power into the box, while rubber grommets handle all other cabling. Durable metal cable management clips and zip tie mounting points take care of messy cables.
The innovative foldable new-construction box allows contractors to run cabling and install drywall keeping the mount safe and scuff-free in its packaging until the job is complete.
Kanto R600 TV Mount Mediabox
Kanto R600 TV Mount Recessed Mediabox
R600 Key Features:
  • OVERSIZED BOX – Store bulky TV breakout boxes, mini AV receivers, and cable set-top boxes behind your TV with R600’s spacious in-wall box. An accessory plate allows easy access and removal of components for servicing.
  • PERFECT PLACEMENT – Get your TV perfectly flush against the wall with the included 300×300 VESA plate, or dial in the perfect height and horizontal offset of your TV with the larger 800×600 interface
  • CONTRACTOR FRIENDLY – A foldable, in-wall template for new-construction can be temporarily placed between studs letting contractors plan cabling and drywall while the mount sits safely in its packaging until needed
  • POWER WHERE YOU WANT – Metal knock-outs allow for the installation of power outlets inside the box so you can keep everything needed to power your equipment within the wall
  • CLEAN CABLING – Metal cable management clips run along the length of the articulating arm while rubber grommets within the box help you to route your cabling without any mess
The Kanto R600 is $349.99 at Crutchfield.
Kanto TTS140
TTS140 Height Adjustable & Swivelling Tabletop TV Stand Lifestyle
Elevate your large screen experience with the new Kanto TTS140 adjustable tabletop TV stand. This tabletop TV mount surpasses the included TV legs stands by accommodating screens up to 125 lbs while providing additional features.
The single column design features 24” of height adjustment along with 32° of swivel left or right. Improve the line of sight with your display by tilting your screen up to 10° forward or 5° backward. Upgrade your TV setup with the TTS140 for a non-invasive installation and enhanced features not found with included TV stands.
TTS140 Key Features:
  • LARGE TV SUPPORT – The TTS140 tabletop TV stand is designed to keep even the largest TVs secure. The sturdy column design supports 90” screens weighing up to 125 lbs.
  • FULLY ADJUSTABLE – Adjust your TV to the optimal viewing angle using the 32° swivel, +10° to -5° tilt, horizontal leveling, and height adjustment. This swiveling TV stand provides superior maneuverability for an enhanced viewing experience compared to standard TV stands.
  • SOLID AND SECURE – For increased stability, use the included safety tether to anchor your screen to the wall protecting your investment and allowing you to enjoy your TV with complete peace of mind.
  • SIMPLE INSTALLATION – TTS140 tabletop TV stand is not only simple to install, but also prevents damage to your walls. The minimalistic design seamlessly merges with your décor, creating a stylish look.
  • CABLE MANAGEMENT – Keep your entertainment area clean and free of distractions by running your cables down the center of the column.
The Kanto TTS140 is priced at $229.99.
Price & Availability
The Kanto PMX800, R600, and TTS140 TV Mounts are available now, pricing as follows:
The new Kanto PMX800, R600, and TTS140 mounts will be on show at this year’s CEDIA, Booth C712, September 5th-7th, in Denver, CO. Find out what else is new at CEDIA 2024.
Check Amazon for additional Kanto Mount styles.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Just add in-ceiling speakers to Q Acoustics 300A Ceiling Amplifier to bring streaming music and Amazon Alexa into any room.
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Audio Cables
At $160 to $500, this hybrid HDMI cable uses copper and optical to deliver 48 gbps of performance in long lengths up to 20...
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new...
Digital Music Systems
At $2,499, the NAD M10 V3 (3rd gen) streaming amplifier adds a MM phono input along with Dirac Live Room Correction and Bass Control.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
