Kanto Audio Introduces ORA4 Desktop Speakers: CES 2024
Powerful 70-watt desktop speakers, featuring Bluetooth 5.0, USB-C input supporting 24-bit/96kHz, analog RCA Line-in, and Sub-out for $399.
Kanto Audio ORA4 Wireless Speakers in Black
The new ORA4, from Canadian speaker manufacturer Kanto Audio, builds upon the success of their recently launched ORA Desktop Speakers
The Kanto Audio ORA4 features Bluetooth 5.0 connectivity, Analogue Line-in, and a USB-C input that supports audio up to 24-bit/96kHz.
The USB Type-C port allows users to connect a host of audio sources to the ORA4 including iPhone 15, Android devices, Digital Audio Players, PC, Mac, and more.
A powerful desktop speaker — ideal for listening to music, gaming, or for use as a home or remote recording studio monitor — the new ORA4 features separate Class D amplifiers for the woofers/tweeters, delivering a dynamic audio presentation with a smooth, accurate frequency response. ​
The Kanto Audio ORA4 also includes a subwoofer output, with a built-in automatic crossover at 80 Hz that high-passes the speakers and low-passes the sub-out, enabling seamless integration with a powered subwoofer — such as the Kanto Audio SUB8.
Each ORA4 speaker employs separate amplifiers for both woofers and tweeters, ensuring an accurate frequency response during playback.
Power output per tweeter is 12W, and per woofer 23W, for a combined bi-amplified power output of 70W. ​
With the ORA4, Kanto Audio has engineered a high-performance compact speaker perfect for desktop use which — no matter the source — delivers clear highs, detailed midrange, and an impressively powerful bass. ​
Specifications
ORAORA4
MSRP$349$399
Tweeter3/4-inch Silk Dome3/4-inch Silk Dome
Woofer3-inch Paper Cone
(Magnetically Shielded)
4-inch
Amplifier TypeClass D Bi-amplifiedClass D Bi-amplified
Power Output50W RMS
(100W Peak Power)
70W RMS
(140W Peak Power)
Power Output (Per Tweeter)9W RMS12W RMS
Power Output (Per Woofer)16W RMS23W RMS
Frequency Response70Hz – 22kHz60Hz – 22kHz
High/Low-Pass Filter100Hz (Automatic)80Hz (Automatic)
Inputs1 x RCA Line-level
1 x USB-C (up to 24-Bit / 96 kHz)
1 x Bluetooth 5.0
1 x RCA Line-level
1 x Bluetooth 5.0
Outputs1 x Sub-out1 x Sub-out
Speaker Terminals4-pin Connector4-pin Connector
Rear Mounting Hole1/4-inch -201/4-inch -20
Input Voltage / FrequencyAC 100V – 240V (50/60Hz)AC 100V – 240V (50/60Hz)
Standby Power Consumption< 0.5W< 0.5W
Dimensions (WxDxH) (Single Speaker)3.9-inch x 5.6-inch x 6.9-inch
(10cm x 14.1cm x 17.5cm)
Weight (Single Speaker)2.2lb / 1kg?
Boxed Weight (Pair)8.2lb / 3.7kg?
Box Dimensions (WxDxH)8.9-inch x 15.1-inch x 10-inch
(22.7cm x 38.3cm x 25.4cm)
Kanto Audio ORA 4 Desktop Speaker system will be available from April, priced £349 / $399.
Continue reading more stories from CES 2024.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
A/V Furniture & Accessories
Need to wall mount an extra large display or looking for a swivel TV stand? Kanto has three unique solutions under $400.
HDTV 4K & 8K TV
For 2024 Samsung unveils a feature-packed 4K & 8K TV line-up, including more 98-inch sets, updated video and audio processing, and new OLED Glare...
HDTV 4K & 8K TV
In 2024 Roku will introduce its best 4K TVs ever. New Pro Series models feature QLED and Mini-LED technology in 55", 65" and 75"...
HDTV 4K & 8K TV
The 2024 Samsung OLED 4K TV lineup ranges in size from 42 to 83-inches, priced from $1,399 to $5,399.
HDTV 4K & 8K TV
2024 LG OLED TVs promise improved visuals thanks to more powerful AI image processing and up to 4K 144Hz refresh rate for gaming.
For 2024 Samsung is introducing four new soundbars and a unique wireless speaker called the Music Frame.
At CES 2024, Sennheiser is introducing three new wireless noise cancelling headphones designed for fitness, travel, or audiophiles.
