Car Speakers
JVC V6 Car Coaxial Speakers
Improved Crossover Design enhances mid-range response
JVC Mobile Entertainment’s V6 speaker line includes five new models, featuring twin roll rubber edges for vertically symmetrical movements, increased total amplitude, increased sound pressure and less distortion. The 2010 2-way speakers also feature improved crossover design between woofer and tweeter response. The improved crossover design cuts excess ultra high-range and enhances mid-range signals. The custom fit size CS-V6835 6″ x 8″ / 5″ x 7″ and CS-V4625 4″ x 6″ Coaxial speakers from 2009 are also returning to the 2010 lineup.
JVC CS-V6946
JVC Mobile’s CS-V6946 is a 6″ x 9″ 4-way speaker with a frequency response of 28Hz to 25,000Hz and 330W peak / 60W RMS power handling. The speaker is composed of aramid fiber and carbon fiber composite olefin cone woofer, poly-ether imide dome super tweeter, and contains a heat-resistant voice coil. The CS-V6946 speaker will carry an MSRP of $79.95.
JVC CS-V6936
JVC CS-V6936
JVC Mobile’s CS-V6936 is a 6″ x 9″ 3-way coaxial speaker with a frequency response of 28Hz to 25,000Hz and 290W peak / 40W RMS power handling. The speaker is composed of aramid fiber and carbon fiber composite olefin cone woofer, poly-ether imide dome tweeter, and contains a heat-resistant voice coil. The CS-V6936 speaker will carry an MSRP of $69.95.
JVC CS-V626
JVC CS-V626
JVC Mobile’s CS-V626 is a 6-1/2″ 2-way coaxial speaker with a frequency response of 35Hz to 25,000Hz and 210W peak / 30W RMS power handling. The speaker is composed of aramid fiber and carbon fiber composite olefin cone woofer, poly-ether imide dome tweeter, and contains a heat-resistant voice coil. The CS-V626 speaker will carry an MSRP of $49.95.
JVC CS-V526
JVC CS-V526
JVC Mobile’s CS-V526 is a 5-1/4″ 2-way coaxial speaker with a frequency response of 40Hz to 24,000Hz and 190W peak / 27W RMS power handling. The speaker is composed of aramid fiber and carbon fiber composite olefin cone woofer, poly-ether imide dome super tweeter, and contains a heat-resistant voice coil. The CS-V526 speaker will carry an MSRP of $39.95.
JVC CS-V426
JVC CS-V426
JVC Mobile’s CS-V426 is a 4″ 2-way coaxial speaker with a frequency response of 45Hz to 24,000Hz and 160W peak / 20W RMS power handling. The speaker is composed of aramid fiber and carbon fiber composite olefin cone woofer, poly-ether imide dome super tweeter, and contains a heat-resistant voice coil. The CS-V426 speaker will carry an MSRP of $29.95.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
