JVC TH-BA1 and TH-SB100 Sound Bar Home Theater Systems
JVC TH-BA1
Two 4.1-channel systems debut – both with wireless subwoofer, one with Blu-ray player
JVC offers a simple solution to top-quality home theater sound with the introduction of two new home theater systems. The new TH-BA1 and TH-SB100 are both 4.1-channel systems that feature a low-profile front surround sound bar and wireless subwoofer. Both systems combine sleek design and simple setup with performance that delivers clear dialog and convincing surround sound.
The sound bar is configured to fit neatly under a TV or can be wall-mounted. Its front surround technology eliminates the need for rear speakers and the placement problems, clutter and extra wiring that comes with them. A single cable connects the sound bar to a source (DVD or Blu-ray player) or TV via each systems’ two digital optical inputs and one analog input. And to further simplify setup, the included subwoofer is wireless. The TH-BA1 includes two components – the sound bar and wireless subwoofer, while the TH-SB100 adds a separate Blu-ray player to the package.
The black, low-profile sound bar includes four speakers, an amplifier and a sound processor. It also features built-in Dolby Digital, Dolby Pro Logic II and DTS decoding. Total system power is 220W, with each speaker within the sound bar amplified and housed in a separate internal structure to prevent interference. The virtual surround sound is based on JVC’s own front surround technology. The two outboard speakers deliver the left and right channel information, while the middle two speakers each deliver center channel information plus the surround/left and surround/right channels. The result is clear dialog and an immersive soundfield.
The subwoofer features a 6-5/6-inch (8cm) driver and is powered by its own built-in 100-watt digital amplifier. 2.4GHz digital wireless technology connects the subwoofer to the sound bar, and eliminates the need for a cable connection, providing simple setup and placement flexibility.
Power on/off, volume adjustment and source/surround mode selection can be operated using the provided remote control.
To the sound bar and subwoofer of the TH-BA1, the TH-SB100 adds a freestanding JVC Blu-ray player. In addition to Blu-ray discs, the player offer playback of the AVCHD format, the widely used HD camcorder format. Other features include BD Live compatibility when used with USB memory. Player connections include HDMI ver.1.3 with Deep Color and x.v.Color, USB Host, LAN for BD Live, component and composite video outputs, and analog, optical and coaxial audio outputs. In addition to AVCHD, other playable formats are JPEG, MP3, WMA, Dolby Digital, Dolby Digital Plus, Dolby True HD, DTS and DTS HD.
The TH-BA1 and TH-SB100 will be available in September for $399.99 and $699.99, respectively.
About JVC U.S.A.
JVC U.S.A., headquartered in Wayne, New Jersey, is a division of JVC Americas Corp., a wholly-owned subsidiary of Victor Company of Japan Ltd. JVC distributes a complete line of video and audio equipment for the consumer and professional markets.
Specifications
Model Name TH-BA1 & TH-SB100
Main Speaker
Type Full range bass-reflex, magnetically shielded
Full range 3-3/16 inch (8cm) Cone x 4
Power output 30W x 4
Decoder Dolby Digital, Dolby Pro Logic, Dolby Pro Logic, DTS
Impedance 4 ohms
Dimensions (W x H x D) 35-3/8 x 4-9/16 x 3/3/16 inches (900 x 115 x 80mm)
Weight 11.46 lbs. (5.2kg.)
Wireless Powered Subwoofer
Type 1-way bass-reflex
Speaker 6-5/16 (16cm) Cone
Power output 100W
Impedance 3 ohms
Dimensions (W x H x D) 8-1/2 x 13-7/8 x 10 inches (215 x 352 x 254mm)
Weight 12.7 lbs. (5.8kg.)
XV-BP1 Blu-ray Player (included only with TH-SB100)
BD Live™ Yes
Playable Media BD-ROM/BD-RE/BD-R, DVD-Video/DVD-R/-RW, DVD +R/+RW, BD-ROM, BD-RE, BD-R, DVD-Video, DVD-R, DVD-RW (Video/VR), +RW/+R, CD/CD-R/-RW
Playable Formats (Image) MPEG-2, MPEG-4 AVC (H.264), VC-1, AVCHD, JPEG Digital Still
Playable Formats (Audio) LPCM, Dolby Digital/Dolby Digital+, Dolby TrueHD, DTS, DTS HD, MPEG-1/-2 L2, MP3, WMA
Video:
Video D/A Converter 12-bit/148MHz
NTSC – PAL Conversion Yes
Deep Color Yes
x.v.Color™ Yes
1080p Upscaling Yes
Terminals HDMI Digital Out (Audio/Video), Component, Composite, Audio Out, Analog 2ch, Coaxial Digital Output, Optical digital Output, USB Host 2, Network (Ethernet)
Power Consumption Power On: 26W; Standby: Less than 1W
Dimensions (W x H x D) 16-15/16 x 2-5/16 x 10 inches (430 x 58 x 253mm)
Weight 6.2 lbs (2.8 kg.)
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
