Camcorders
JVC PICSIO GC-FM1 Pocket Camcorder
Pocket Camera Shoots HD Video & 8 Megapixel Stills
JVC announced the launch of its first pocket flash memory camera, the new PICSIO GC-FM1. PICSIO is designed for those who want a small, simple, camera that allows easy sharing and delivers high quality video and still images.
PICSIO shoots eight-megapixel stills and 1080p HD video for outstanding results even when viewed on an HDTV. Further enhancing the quality of PICSIO’s video is image stabilization that minimizes camera shake, even when the 4X digital zoom is used. The camera is about the size of a small cell phone, and is available in three colors – Black Ice, Blue Steel and Purple Passion. It boasts a stylish design with a case that features a tone-on-tone geometric pattern and chrome accents for a jewel-like appearance.
PICSIO’s high quality images result from the use of an eight-megapixel CMOS image sensor that captures JPEG stills with up to eight-megapixel native resolution – there’s no image-degrading interpolation, so PICSIO images are sharp and vibrant, whether viewed on a screen or printed. In video mode, PICSIO records HD video that’s easily enjoyed on an HDTV by using the camera’s HDMI connection. Videos are recorded in the widely-used MPEG-4 AVC/H.264 format and stored as .MOV files for easy sharing without the need for time-consuming and potentially damaging conversion. Storage is on readily-available SD/SDHC memory cards.
To suit individual shooting situations, PICSIO provides four video and still recording modes:
JVC PICSIO GC-FM1B Pocket Camcorder
Video Recording
Mode Image size Frame Rate
1080p 1440 x 1080p 30 fps
720p 1280 x 720p 60 fps
VGA 640 x 480p 60 fps
QVGA 320 x 240p 30 fps
Still Recording
Mode Image size Aspect Rate
8 M 3264 x 2448 4:3
5 M 2592 x 1944 4:3
2 M 1600 x 1200 4:3
0.3 M 640 x 480 4:3
Ease-of-use was a top priority in designing PICSIO, so instead of lengthy menus to scroll through, functions are easily selected directly using logically placed dedicated buttons. Power (on/off), playback, delete, video/still mode switching, and thumbnail display mode all have their own individual buttons. A four-way controller positioned in the middle controls zoom (by pressing up/down), still image viewing (by pressing left/right), and record start/stop (the center button). The large, two-inch LCD also makes shooting easy.
Connectors include HDMI™ out (Mini), AV out and USB 2.0/1.1. The camera charges via USB connection, so it automatically charges whenever connected to a PC and not transferring files. USB cable, AV cable, hand strap and PC software – loaded into the camera’s internal memory – are included with the camera.
PICSIO Feature Highlights
  • Stylish Pocket-Fitting Design in Choice of Colors
  • “Menu-less” Simple & Easy Operation
  • Direct Sending to iTunes/YouTube™ (.MOV file)
  • Image Stabilizer
  • 8 Megapixel Still Image Recording
  • 1080P/30fps HD Video Recording
  • 4x Digital Zoom
  • Convenient USB Battery Charging
  • HDMI™ and AV Output Terminal
  • SD/SDHC Card Compatible (up to 32GB)
  • 2.0″ Color LCD
The JVC Picsio GC-FM1 is available now for $199.95.
Image Sensor 8 Megapixel 1/3.2″ CMOS
Zoom Digital 4x
Image Stabilization Digital Image Stabilizer
Recording media SD/SDHC Card (not provided)
Monitor 2.0″ Color LCD
Video Recording Mode 1080p: 1440 x 1080p / 30fps / 12Mbps, 16:9
720p: 1280 x 720p / 60fps / 12Mbps, 16:9
VGA: 640 x 480 / 60fps / 4Mbps, 4:3
QVGA: 320 x 240p / 30fps / 0.7Mbps, 4:3
Format Video: MPEG-4 AVC / H.264: MOV, Audio: AAC
Still Recording Mode 8M: 3264 x 2448, 4:3
5M: 2592 x 1944, 4:3
2M: 1600 x 1200, 4:3
0.3M: 640 x 480, 4:3
Format JPEG
Connectors HDMI™ out (Mini), AV out, USB 2.0/1.1
Others PC Software and Instruction Manual (pre-installed in internal memory)
Continuous Operation Time Approx. 96 minutes
Provided Accessories USB Cable, AV Cable, Hand Strap
Dimensions (W x H x D) 53.0mm x 97.0mm x 17.0mm (2-1/8″ x 3-7/8″ x 11/16″)
Weight Approx. 95 g (0.21lbs)
Notes:
SD/SDHC card is not supplied. To record video, SDHC card with Class 4 or higher performance is required. Digital stills can be recorded on both SD and SDHC cards. SD memory cards (256MB to 2GB) and SDHC memory cards (4GB to 32GB) have been tested for the following brands: Panasonic, Toshiba, SanDisk, ATP. Note that using other media may result in recording failure or data loss. Recording time figures are estimations. There may be cases where actual recording time becomes shorter depending on the type of content being recorded.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
