JVC LT-42SL89 and LT-46SL89 Thin Bezel LCD HDTVs Announced
JVC To Offer World’s Thinnest Tuner-Equipped LCD TV With Sleek, Thin-Bezel Design and Reduced Power Consumption In Two Screen Sizes
Establishing a new benchmark in flat panel TV design, JVC in July will market the world’s thinnest LCD TVs with built-in tuners*. The new line of super-slim Full HD TVs also weigh less and consume less power than conventional LCD TVs.
JVC’s new slim LCD TVs, part of the company’s Procision series, feature a cabinet that across most of its width measures a mere 1.5 inches (39mm) deep, with a maximum depth of just 2.9-inches (74mm) at the panel’s center. The design ensures that from nearly any angle, the sets present a super-slim appearance. Complementing the slim design is a thinner bezel, further minimizing the presence of the cabinet.
LT-46SL89
The new super-slim design will be available in two screen sizes in the U.S., the 42-inch LT-42SL89 and the 46-inch LT-46SL89. Both offer 1920 x 1080p resolution.
The slim design was made possible through the use of a new JVC-developed slim panel backlight unit and power supply substrate, or chassis. The new slim LCD panel backlight unit is 40 percent smaller in depth and bezel width compared to a conventional LCD backlight, measuring just 0.79 inches (20mm) deep and 0.51 inches (13mm) wide. In addition, the unit weighs only 26.4 lbs (12kg) and consumes a mere 145W (see diagram 1).
*with built-in tuners as of January 6, 2008, according to a JVC survey
Efforts to reduce the depth of an LCD panel backlight result in uneven hot spots appearing on the LCD screen surfaces because CCFL light sources are brought closer to the liquid crystal panel (see diagram 2). To overcome this problem, either light-diffusing plates are applied or more CCFL tubes are used. But the former approach can result in lower brightness, while the latter approach can be costly and increases power consumption.
JVC’s display engineering team succeeded in developing a new, slimmer backlight unit by optimizing the light-diffusing plates and light-reflection sheets, as well as improving its overall composition. This provided uniform light-diffusion at all the corners and edges without the addition of more CCFL tubes, while maintaining adequate luminance to ensure that the screen always remains bright (see diagrams 3 and 4).
JVC also developed a slimmer yet efficient power-supply substrate and employed a direct-mount configuration for it on the LCD panel backlight unit with a fan-less heat dissipation system to further reduce power consumption.
Both models will be VESA compliant for easy wall mounting, but JVC will also offer its own mounting solution – a wall mount designed to position the slim TV closer to the wall than does a standard mount.
Both sets include a full complement of connections, including three HDMI inputs, two component inputs, one S-Video in and a PC input. Other features include front touch sensor controls, a headphone jack, USB picture viewer and an illuminated universal remote control.
The new JVC super-slim LT-42SL89 and LT-46SL89 will be available in July with approximate retail prices of $1,899.99 and $2,399.99, respectively.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
