Headphones
JVC HA-EB75 Ear Clip Headphones
JVC HA-EB75 Ear Clip Headphones - Black
Feature an adjustable ear clip and three color choices for sports and fitness enthusiasts
Active music lovers looking for a secure-fitting headphone now have another option with the introduction of new JVC adjustable ear clip headphones, available in a choice of three colors.
Designed for sports and other active use, the affordable JVC HA-EB75 splash-proof headphones incorporate a soft rubber ear clip that fits around the outer ear to hold the earbud in place. To ensure a comfortable and secure fit, the ear clip is adjustable, with a slide mechanism that offers five different positions to adjust to different size ears.
To ensure high quality sound reproduction, a 0.53-inch (13.5mm) neodymium driver in each earpiece provides powerful sound with bass boost earpieces to deliver rich audio quality. Also, the splash-proof design helps protect the headphones from the elements. The headphones come with a four-foot (1.2m) friction noise reduction cord and an iPhone-compatible plug.
The JVC HA-EB75 Ear Clip headphones come in three iPod matching colors: silver, black, and blue. They will be available this month for $12.95.
JVC HA-EB75 Ear Clip Headphones - Blue
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
