Monitors
JVC Expands Display Line with HD Flat Panel Monitors for Broadcast and Post Production Applications
FOR IMMEDIATE RELEASE
JVC EXPANDS DISPAY LINE WITH HD FLAT PANEL MONITORS FOR BROADCAST AND POST PRODUCTION APPLICATIONS
Wayne, NJ (February 12, 2007) — Continuing to redefine its premium display line, JVC is excited to introduce two professional broadcast monitors, the DT-V24L1DU, 24-inch monitor and the DT-V20L1DU, 20-inch monitor. Featuring 16:9 aspect ratio, wide viewing angle, high-speed LCD and precise color reproduction, these monitors are ideal for broadcast and post-production facilities where image accuracy is vital.
“These multi-format professional monitors were created to meet the demanding needs of broadcast applications where ultra-high resolution, advanced signal processing and color reproduction are extremely important,” said Edgar Shane, senior product engineering manager, JVC Professional Products Company. “The wide array of image controls and professional features make these monitors an ultimate choice for broadcast and post-production applications.”
The DT-V24L1DU features 1920 x 1080 native HD resolution and the DT-V20L1DU features 1680 x 945 HD resolution. The DT-V24L1DU and DT-V20L1DU flat panel monitors feature built-in HD-SDI and DVI-D digital inputs, which provide direct connection to broadcast and studio sources.
Key professional features include high-resolution panel with precise control of back light, brightness and contrast, blue check, color off, two-color tally lamp and area markers. Rugged all-in-one design with rotary-type and direct function image controls, audio speakers and high-speed LCD panel provide easy integration into studio environment.
The DT-V24L1D and DT-V20L1D flat panel monitors are compatible with a variety of external control interfaces such as RS-232 and RS-485. With easy installation both monitors can be mounted using standard VESA compliant mounting brackets and tabletop stands.
The suggested list price of the DT-V24L1D is $4,695.00 and the DT-V20L1D is $3,495.00. For more information and high-resolution photos, please visit JVC’s Web site at http://pro.jvc.com/newsroom.
ABOUT JVC PROFESSIONAL PRODUCTS COMPANY
JVC Professional Products Company, located in Wayne, New Jersey, is a leading manufacturer and distributor of a complete line of broadcast and professional equipment. For more information about this, or any other JVC Professional Products Company product, contact JVC at (800) 582-5825; or Candace Vadnais at PFS Marketwyse 973-812-8883, ext. 430 or visit JVC’s Web site at http://pro.jvc.com.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
