Car Subwoofers
JVC DRVN CS-GD1200 and CS-G1200 Car Subwoofers
JVC will continue to offer the DRVN series CS-GD1200 and CS-G1200 car subwoofers in 2012 which have been engineered to work in enclosures as small as .75 cubic feet.
CS-GD1200
The CS-GD1200 is a dual voice coil with butyl rubber surround. The dual voice coil features a 62.6 oz strontium magnet. It has 1400W peak/400W RMS power handling, and it is available now for $149.95.
JVC DRVN CS-G1200 Car Subwoofer
CS-G1200
The CS-G1200 is a single voice coil with urethane surround for fast response. The single voice coil magnet is 39 oz strontium magnet. It has 1200W peak/250W RMS, and it is available now for $99.95.
Specifications
CS-GD1200 CS-G1200
MSRP $149.95 $99.95
Cone Size 12-inches (30cm) 12-inches (30cm)
Max Power 1400 Watts 1200 Watts
Continuous Power (RMS) 400 Watts 250 Watts
Voice Coil Dual Single
Cone Type Sputtering Olefin Diaphragm Sputtering Olefin Diaphragm
Frame Stamped Steel Stamped Steel
Surround Butyl Rubber High-Density Foam
Gasket Super Heat-Resistant ABS Super Heat-Resistant ABS
Magnet 62.6 oz (1.774g) Strontium 39 oz (1.106g) Strontium
Terminals Silver-Plated Push 8AWG Ready Silver-Plated Push 8AWG Ready
Frequency Range 20 – 2000Hz 20 – 2500Hz
Sound Pressure Level (SPL) 86.5dB/W.m 87.5dB/W.m
Mounting Depth 5-25/32″ (146.3mm) 5-9/16″ (140.6mm)
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
At $699, the Acoustic Energy AE Sub is 12-inch subwoofer packing 250-watts of power with low bass extension down to 26Hz.
The Audioengine S6 Compact Subwoofer is their smallest, but a perfect match for your desktop home office audio system.
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new...
The REL Classic 99 subwoofer carries on the vintage design of the previously released Classic 98 but with a larger 12-inch driver and increased...
