Car Speakers
JVC DRVN Car Speakers Announced for 2013
JVC CS-VS608
For 2013, JVC announced an updated lineup of DRVN entry level coaxial and component speaker options including five new coaxial selections plus two continuing custom fit sizes and a component system package. Woofer drive cones feature Carbon Mica combined with a hybrid surround comprised of cloth and rubber for enhanced longevity and light, quick playback response. Carbon Mica cones use a thin yet hard profile to increase response accuracy. Using this combination of materials, SPL response has increased throughout the entire frequency range versus previous models. Speaker grilles include a tri-way design, which balances the midrange output to fill the vehicle uniformly. They also feature a Poly-Ether Imide cone midrange, tweeter, and super tweeters while both woofer and midrange or tweeter drivers feature strontium ferrite magnets.
CS-VS608
The CS-VS608 is a 6.5-inch 2-way component speaker set with 300-watt peak power handling and 60-watt RMS power handling. It features a separate PEI tweeter, multiple mounting bracket options and an in-line crossover network box. The set will be available in January for $109.95.
CS-V6948
The CS-V6948 is a 6-inch by 9-inch 4-way coaxial speaker with 400-watt peak power handling and 60-watt RMS power handling, and will be available in January for $89.95.
CS-V6938
The CS-V6938 is a 6-inch by 9-inch 3-way coaxial speaker with 400-watt peak power handling and 60-watt RMS power handling, and will be available in January for $79.95.
CS-V628
The CS-V628 is a 6.5-inch 2-way coaxial speaker with 250-watt peak power handling and 40-watt RMS power handling, and will be available in January for $59.95.
CS-V528
The CS-V528 is a 5.25-inch 2-way coaxial speaker with 220-watt peak power handling and 27-watt RMS power handling, and will be available in January for $59.95.
CS-V428
The CS-V428 is a 4-inch 2-way coaxial speaker with 200-watt peak power handling and 20-watt RMS power handling, and will be available in January for $59.95.
The 6-inch by 8-inch and 4-inch by 6-inch custom-fit coaxial speakers continue into 2013 from the previous DRVN lineup.
CS-V6837
The CS-V6837 coaxial speaker features 250-watt peak power handling and 30-watt RMS peak handling plus a PEI midrange cone and tweeter. It is currently available for $99.95.
CS-V4627
The CS-V4627 coaxial speaker features 140-watt peak power and 20-watt RMS power. It is currently available for $79.95.
4 Comments
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
