JVC DLA-X90R / DLA-RS65 D-ILA THX 3D 4K Projector
JVC announced their flagship home theater projector, the Procision Series DLA-X90R (also known as the Reference Series DLA-RS65) D-ILA Projector capable of displaying theater-quality 3D as well as 2D material upconverted to a stunning 4K resolution. It features JVC’s new e-Shift technology capable of projecting images with 3840 x 2160 pixel resolution, four times that of full HD. Built from hand selected perfectly matched components and given a specialized final calibration, each projector achieves a 120,000:1 native contrast ratio, plus ISF and THX certifications. Both models come with two pairs of 3D glasses and a PK-EM1 3D Signal Emitter.
The Procision Series model will be marketed by JVC’s Consumer Electronics Group, and the Reference Series will be available through JVC Professional Products Company. The projectors are the same, except for the naming and gold accents on the Reference Series.
JVC’s new e-Shift technology processes the original 1920 x 1080 signal with a correlation detection algorithm to uncover detail that can be enhanced on a 4K display. This enhancement improves edge transitions, eliminates aliasing and stair-stepping, and increases contrast in detailed areas. New sub pixels are generated based on this detection and a 3840 x 2160 frame is created. This frame is then temporally separated into subframes 1920 x 1080 pixels each and projected using the D-ILA optical system and through the e-Shift device. This device utilizes a property of liquid crystals called birefringence and can switch between straight light and refracted light by 0.5 pixel both vertically and horizontally. It has no moving parts. The result is an image with 4 times the pixel density of the original content. See more technical data on JVC’s product page.
Features
  • 1920×1080(x3) 0.7-inch D-ILA devices with e-Shift 4K device
  • 2D upconversion to 3840 x 2160 for 4K precision projection
  • Higher pixel density eliminates stair stepping and improves edge transitions.
  • Upgraded optical engine and driver for smoother gradations and reduced motion blur
  • Native contrast ratio: 120,000:1
  • 120Hz Clear Motion Drive for smooth action scenes
  • Real Color Imaging Technology ensures rec.709 color gamut
  • Expanded user adjustment of picture tone and dark gradations
  • 16-step lens aperture
  • 7-axis Color Management System (R,G,B,C,M,Y and Orange)
  • 255 custom screen-mode presets
  • 1/16th pixel convergence adjustment possible with 121 adjustment zones
  • Various color profiles including rec.709/D65, Adobe, sRGB, and DCI
  • Improved driver for increased brightness while reducing crosstalk
  • Parallax adjustment for fine tuning 3D effect
  • Highly customizable built-in 2D-3D converter based on high end JVC production design
  • Includes 2 pairs of active shutter glasses and IR emitter
  • Accepts all modern 3D formats (Blu-ray, side-by-side, top-and-bottom)
  • Designed to achieve THX 3D certification and is scheduled for testing by THX
  • Dual HDMI 1.4a inputs, PC input
  • LAN connection for system control and firmware updates
  • Remote control via LAN, RS-232C, IR
  • Newly designed remote controller
  • V: 80%/H: 34% motorized lens shift
  • New lens memory mode with three user memories
    Maintains constant height for 2.35, 1.85, 1.78 on same screen.
  • 1.4:1 to 2.8:1 lens throw
  • Motorized lens cover
Price and Availability
The JVC DLA-X90R / DLA-RS65 projector will be available November 2011 for $11,999
LG StanbyME 2 Portable TVs
HDTV 4K & 8K TV
LG's new StanbyME 2 is a portable smart touchscreen TV with a detachable design, QHD screen, built-in battery, and flexible placement.
Pro-Ject E1.2 Turntable Top Black Pro-Ject E1.2 Turntable Top Black
Pro-Ject E1.2 delivers audiophile-grade performance at a budget price. A real entry-level winner with serious upgrades and no gimmicks—just sound.
Cambridge Audio Melomania P100 SE White Headphones in hand Cambridge Audio Melomania P100 SE White Headphones in hand
Cambridge Audio's Melomania P100 SE brings audiophile-grade ANC, 100-hour battery life, and aptX Lossless Bluetooth in a sleek £249/$299 package.
Audio Advice Revelation Luxury Home Theater Chairs with Underneath Lighting On Audio Advice Revelation Luxury Home Theater Chairs with Underneath Lighting On
A/V Furniture & Accessories
Tired of sharing a stained IKEA couch with your dog? The Revelation Luxury chair from Audio Advice brings heat, massage, USB-C, and legit comfort...
Epson ProCinema LS9000 projector. Epson ProCinema LS9000 projector.
With true 4K resolution, a bright colorful image and a motorized lens for maximum flexibility, Epson's new Pro Cinema LS9000 offers a lot of...
Onkyo C-30 CD Player Black Front Onkyo C-30 CD Player Black Front
CD Players
Onkyo's new Icon C-30 CD player brings audiophile tech at a surprising price. Discover why physical CDs still matters at Audio Advice Live 2025...
Amazon Prime Day is July 8-11, 2025
Daily Deals
Amazon Prime Day is a four-day shopping event from July 8-11, 2025 offering the biggest discounts of the year on consumer electronics.
