JVC DLA-SH7NL D-ILA 4K2K Projector
5,000 Lumens of Brightness and Low Running Costs; Available in Japan
JVC (Victor Company of Japan, Limited) announced today the early-March launch of the DLA-SH7NL, a 4K2K D-ILA projector incorporating three 1.27-inch 4K2K D-ILA display devices for high-quality imaging and dual ultra-high-pressure mercury lamps for 5,000 lumens of brightness. Combining superb definition and resolution with low-cost maintenance, the 4K2K D-ILA projector is expected to be widely accepted for planetariums, museums, simulators and medical institutions, as well as used for high-spec designing and monitoring.
The new model join the DLA-SH4K, which debuted in January 2008 as 4K2K D-ILA projector and quickly drew high praise. Like its predecessor, the DLA-SH7NL achieves ultra-high resolution of approximately 10 megapixels (4,096×2,400), or more than four times full HD, plus a stunning 10,000:1 native contrast ratio.
Notable features of the new DLA-SH7NL include the following:
  • Dual 330W ultra-high-pressure mercury lamps, producing 5,000 lumens of brightness. In single lamp mode, the DLA-SH7NL can automatically choose the lamp with less cumulative operating time for maintenance efficiency. This, plus the addition of a low-power mode, enable lamp life of approximately 3,000 hours, about double that of conventional projectors. Such features allow the DLA-SH7NL to offer low running costs even under heavy professional-use conditions.
  • JVC’s own 4K2K D-ILA devices deliver approximately 10 megapixels of high-resolution, and can simultaneously display two or four screens in WUXGA (1,920 x 1,200) and full-HD resolution. Multi-screen projection is facilitated by four DVI (Dual-Link) input terminals supporting an array of PC input formats.
  • True black quality with stunning 10,000:1 native contrast thanks to a wire-grid optical engine.
  • Weighs only about 50 kg, excluding lens. Elaborate design offers operational flexibility, including stacking two projectors to display 3D images or installation on a 90-degree tilt.
  • Both short-focus and telescopic lenses are optionally available for extended projection applications.
The DLA-SH7NL operates on normal AC 100-220V power and consumes less than 1.1kW, helping to ease power-supply requirements. Color registration of RGB panels in the optical system can be mechanically adjusted in 1/10 pixel accuracy. Six test patterns, including a crosshatch and color bars, enable image adjustment without external signal sources. Three types of gamma tables are incorporated to set tone expression in accordance with specific images.
The Ethernet-compatible DLA-SH7NL can be configured via a PC web browser. Multiple projectors are networkable for operation via a single PC. E-mails can be generated automatically to send lamp-replacement reminders and error-status notifications for enhanced maintenance. The projector’s configuration data are easily stored and uploaded from a USB memory device.
DLA-SH7NL Specifications
Optical System
Display device 1.27-inch D-ILA device x 3 (aspect ratio app. 17:10)
Effective resolution 4,096 x 2,400 pixels
Projection lens Sold separately (see below)
Light source Dual 330W ultra-high-pressure mercury lamps
Lamp life Approx. 3,000hours (assumes 265W mode)
Brightness 5,000 lumens
Contrast ratio 10,000:1 (native)
Supported signals
Digital video input format
(progressive signals only)
4,096 x 2,400, 4,096 x 2,160, 3,840 x 2,400, 3,840 x 2,160
2,048 x 1,200, 2,048 x 1,080, 1,920 x 1,200, 1,920 x 1,080,
1,600 x 1,200, 1,280 x 1,024, 1,024 x 768, 800 x 600, 640 x 480
Input terminals
Image input DVI-D (dual link) 24-pin (12bit expandable) x 4 (HDCP supported)
LAN RJ45 x 1
USB Type B (slave) x 1
RS-232C D-sub 9-pin (male) x 1
Other
Power source AC100V/200V, 50/60Hz
Power consumption 1,100W (6W in standby mode)
Max Current 11A (AC100V)
Operating temperature 10°C – 35°C
Operating humidity Less than 80% (no condensation)
Storage temperature -5°C – 60°C
Dimensions 660 (W) x 342 (H) x 783 (D) mm
Weight 50.5kg, excluding lens
Inclusions Power cord and operating manual
Optional lenses
Type GL-MS4015SZ GL-MS4011S
Projection ratio 1.5:1 – 1.84:1 1.1 : 1
Zoom ratio 1.22x Fixed
Vertical and horizontal shift
(Motorized)
Vertical ±50%
Horizontal ±25%
Vertical ±15%
Horizontal ±5%
Projection distances Approx. 2.6m – 12m Approx. 1.2m – 6.2m
Weight 3.6kg 3.4kg
Castle Windsor Duke Mahogany Loudspeakers Front
Castle Acoustics' Windsor Series Duke and Earl bookshelf speakers are now available through MoFi Distribution. Classic British hi-fi, reborn.
Elipson Connect 2130 Xi Streaming Amplifier Lifestyle Elipson Connect 2130 Xi Streaming Amplifier Lifestyle
Digital Music Systems
Discover the Elipson Connect 2130 Xi, a compact French streaming amplifier that combines high-end Class D power, Wi-Fi and Bluetooth streaming, and HDMI ARC...
Tivoli Audio New Ordinary SongBook Max Speaker Lifestyle Tivoli Audio New Ordinary SongBook Max Speaker Lifestyle
Tivoli Audio's limited-edition SongBook Max, made in collaboration with Grammy-winning producer Sounwave, brings leather, chrome, and serious attitude to a retro-style Bluetooth speaker built...
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
