JVC DLA-RS20 THX Certified D-ILA Projector Announced
New THX Certified DLA-RS20 has the industry’s highest native contrast ratio — 50,000:1.
JVC Professional Products Company today demonstated its 1080p home theater line including the new DLA-RS20, a THX Certified* projector that offers a native contrast ratio of 50,000:1, the industry’s highest. Also shown was its award winning DLA-RS2 configured with an anamorphic lens for 2.35:1 motion picture viewing and the new, affordable DLA-RS10 with a 32,000:1 contrast ratio. JVC’s highly-acclaimed D-ILA projectors achieve high contrast ratios without the use of an auto iris. All are part of JVC’s highly acclaimed Reference Series line of high end home theater products.
Contributing to the DLA-RS20’s superior native contrast ratio is a newly developed lens with a 16-step fixed aperture that helps eliminate extraneous light that can reduce contrast levels and allows adjustment of brightness to suit user preferences. The DLA-RS10 features a 3-step aperture. In addition, changing the structural design of the optical section from a conventional L-shape with a mirror to a straight configuration reduced light leakage. Combining this new structure with a highly efficient lamp allows the DLA-RS20 to achieve a brightness of 900 lumens and the DLA-RS10 to achieve 1,000 lumens.
The DLA-RS20 is THX Certified to ensure accurate and exceptional picture quality in the home theater environment. A trusted cinema and consumer brand, THX certification provides JVC a means to further differentiate its projectors from competitive offerings and communicate a clear message about quality to customers.
Core technologies and many of the features that earned earlier JVC projectors accolades from reviewers and users alike are also incorporated into the new DLA-RS20. But improvements in several key areas allow all four new models to deliver brighter, more intense images. What’s more, JVC has engineered an all-new chassis that is smaller giving the projector a sleeker appearance.
Critical proprietary technologies at the heart of both projectors include JVC’s 0.7-inch full high definition D-ILA devices and the company’s wire-grid optical engine. These deliver the industry’s highest native contrast ratio, meaning that there is no dynamic iris to artificially inflate contrast specifications. As a result, the projectors simultaneously deliver true blacks and extraordinary luminance detail with unparalled contrast ratio.
JVC-developed D-ILA technology employs three (RGB) devices for a naturally rich, flicker-free picture even when there is rapid movement in the image. In addition, the optical engine with wire grid polarizers ensures precise light polarization without light leakage for true black level reproduction. Together, the D-ILA devices and the engine guarantee a smooth picture with vivid colors and high contrast.
Among key new developments found in the new projectors is the use of the HQV Reon-VX video processor developed by Silicon Optix to ensure excellent image reproduction with precision I/P conversion and scaling. In addition, the DLA-RS20 features color management that allows control of colors individually by R, G, B, C, Y, or M, in three separate axes of color phase, chroma saturation and brightness. Up to three customized color settings can be stored for future use.
Also unique to the DLA-RS20 is THX Certification. With a strict focus on image quality and signal processing performance, THX certification promises that the projector is capable of presenting a wide range of video content at maximum resolutions with the correct color and luminance levels. In addition, THX has created a battery of signal processing tests that challenge the projector’s scaling, motion conversion and de-interlacing capabilities. This type of in-depth analysis predicts how the RS20 will present a variety of high definition and standard definition content.
The DLA-RS20 also features the THX Movie Mode, a pre-calibrated video setting for watching movies on DVD, Blu-ray HD or broadcast television. This playback feature is designed to recreate the cinema experience at home by setting the display’s gamma, luminance, color temperature and other settings to mirror those used by filmmakers in post-production. THX Movie Mode also ensures projector brightness is optimal for large screen viewing.
Other features common to the DLA-RS20 and DLA-RS10 include:
  1. High-performance 2x motorized zoom lens. A new high-performance 2x zoom lens with motorized focus, zoom and shift features a large diameter, all-glass lens system with 17 elements in 15 groups that includes an ED lens to project a full HD image with exceptional depth. In addition, a unique automatic lens cover opens when the projector is powered up and closes when powered down to protect against dust.
  2. Customized on-screen gamma control. Manual adjustment of the gamma curve is possible via an on-screen display, allowing the viewer to adjust projector luminance levels by either increasing contrast in scenes that are too dark or dimming washed-out scenes to ensure precise brightness levels suited to individual preferences. Up to three settings can be adjusted and stored for future use.
  3. Flexible set-up. Setup is easy with the ±80 percent vertical and ±34 percent horizontal motorized lens shift function that allows the projected picture to be moved horizontally or vertically via the remote control.
  4. Quiet Operation. A more efficient cooling system reduces fan noise to 19dB.
Both projectors also include an external 12-volt trigger that can be used to automatically raise and lower a screen or draw curtains. Also, an automatic lens cover opens and closes with power on/off.
The projectors comply with HDMI version 1.3 (Deep Color/CEC) specifications, which reproduce subtler shades of grey, and CEC compatibility for system control.
The DLA-RS10 is scheduled to ship this month with a suggested list price of $4,995. The DLA-RS20 will be available in December at $7,495. Both models are part of JVC’s Reference Series high end projector line.
ABOUT JVC PROFESSIONAL PRODUCTS COMPANY
JVC Professional Products Company, located in Wayne, New Jersey, is a leading manufacturer of home theater products and security products in addition to a complete line of broadcast and professional video systems. For more information about this, or any other JVC Professional Products product, contact Candace Vadnais at PFS Marketwyse 973-812-8883, ext. 430 or visit JVC’s Web site at http://pro.jvc.com
* THX certification is pending final testing and approval by THX Ltd.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
