JVC DLA-F110E D-ILA 3D Projector
JVC announced the DLA-F110E D-ILA 3D projector designed for custom installations including high-end conference rooms and DICOM (digital imaging and communications in medicine) applications, delivering 1080p Full HD imagery.
With three, 0.7-inch 1920×1080 D-ILA imagers, the DLA-F110E delivers a naturally rich, flicker-free images with true blacks and extraordinary luminance detail. JVC's wire-grid optical engine helps deliver outstanding 30,000:1 native contrast ratio, and its double-speed 120Hz Clear Motion Drive technology reduces motion blur. The projector provides 1,700 ANSI lumens.
For 3D presentations, the DLA-F110E is compatible with JVC's PK-AG1 Active Shutter 3D Glasses and PK-EM1 3D Signal Emitter (sold separately). The projector includes a HDMI 1.4a port to support side-by-side (broadcast), frame series (Blu-ray), and above-below 3D transmissions. The unit also features a VGA input, RS-232C terminal for IP-based control, and motorized zoom and focus. Plus, its vertical installation capability allows it to be installed at any angle, ideal for confined spaces or otherwise difficult applications.
Features
  • 3D enabled (glasses and IR emitter optional)
  • 1920 x 1080 Native Resolution
  • 3 Active Matrix, 0.7″ Digital D-ILA Devices
  • 30,000:1 Native Contrast Ratio for deep blacks and critical viewing
  • 1,700 Lumen Brightness for higher ambient light environments
  • Digital Smear Reduction via Black-frame Insertion
  • Short Frame Delay
  • 1080p60/50 Synchronous Operation
  • SRGB for a wider color space
  • 850 ANSI Lumens (minimum)
  • 10-Bit Gamma Correction
  • 7- Axis Color Management System
  • 3000 hour, 220W Ultra High Pressure Lamp for Low Operating Cost
  • High Contrast IR output for stimulated NVG applications
  • User Adjustable Gamma Tracking
  • Powered lens shift and 2X zoom lens
  • Wide-Range Zoom, 1.4 – 2.8:1 Throw Ratio
  • ±80% V Offset, ±34% H Offset
  • Can be installed at any angle (for rear screen or mirror installations)
  • Keystone function
  • Comprehensive LAN/RS232/IR Control Protocol
  • Configuration Save/Restore Capability
  • White cabinet color blends well with professional decor
Price and Availability
The JVC DLA-F110E projector will be available through limited distribution in late September 2011 for $7,495.
See more about: Projectors, 3D Projectors, JVC Projectors
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
