Hard Drives
JVC Announces Direct DVD Burning for New Everio Hard Drive Camcorders
Burn DVDs directly from the camcorder with new JVC Everio SHARE STATION.
Owners of select new JVC Everio hard drive camcorders will be able to create DVDs without the need for a PC with the introduction of JVC’s new Everio SHARE STATION, a DVD burner designed specifically for use with three new JVC Everio G-Series camcorders.
The availability of the new JVC Everio CU-VD10 gives users of the company’s Everio hard drive camcorders the best of both worlds — the capacity and convenience of hard drive video recording combined with quick, simple transfer to a DVD.
“Now, consumers can enjoy the benefits of hard drive recording — hours and hours of video capacity, direct access to scenes, easy re-sequencing of scenes, and instant scene deletion — and a quick and easy way to put their footage onto a DVD,” said Dave Owen, General Manager, Consumer Video Division, JVC Company of America.
The new JVC Everio SHARE STATION, available for about $200, connects via a USB cable to the new Everio GZ-MG27, GZ-MG37 and GZ-MG77 and allows the camcorder to transfer footage directly to a DVD. These new Everio camcorders convert .mod files to DVD Video format, which the SHARE STATION then makes into DVD Video discs that can be played on most DVD players.
Once connected via USB 2.0, the camcorder automatically identifies the DVD burner and is used to control the burning process. The desired video clips are selected from a menu that appears on the camcorder’s LCD, and with the push of a button they’re transferred to a blank DVD that had been loaded into the JVC burner. One hour of video footage, which is about 4GB, takes approximately 45 minutes to burn to a disc. Recordings are made using DVD-R/-RW discs.
The Everio SHARE STATION can also be connected to a PC (Windows XP/2000SP4) for DVD burning and reading. Used with recommended DVD-R/-RW discs it offers a write speed of up to 8x (4x RW), and a read speed of 8X (5x RW). It offers a reading speed of 5x for DVD-ROM, and 10x for CD-R, CD-RW, and CD-ROM discs. The burner comes with Power 2 Go data writing software from Cyberlink for PC. Everio camcorders come with Cyberlink’s PowerDirector Express NE for PC editing, PowerProducer 3 NE for PC authoring and PowerDVD 5 NE for PC playback.
JVC’s Everio G Series camcorders, the world’s first hard drive camcorders, eliminate the need to carry tapes, discs or any media at all, yet can record up to seven hours of DVD movie-quality video or more than 10 hours at DVD camcorder-quality. Other advantages of hard drive video recording include the ability to quickly locate desired material, to effortlessly delete unwanted material and to easily rearrange playback sequence. The ground-breaking Everio G Series garnered several awards, including the Sound & Vision Editors’ Choice Award, Men’s Health 100 Best New Products For Men, Popular Science “Best of What’s New” and the CES Innovations 2006 Design & Engineering award.
Pricing and availability
The JVC CU-VD10 Everio SHARE STATION will be available as of April and will sell for about $200.
About JVC Company of America
JVC Company of America, headquartered in Wayne, New Jersey, is a division of JVC Americas Corp., a wholly-owned subsidiary of Victor Company of Japan Ltd., and a holding company for JVC companies located in North and South America. JVC distributes a complete line of video and audio equipment, including high definition displays, camcorders, VCRs, D-VHS recorders, DVD players and recorders, satellite systems, home and portable audio equipment, mobile entertainment products and recording media. For further product information, visit JVC’s Web site at http://www.jvc.com or call 800-526-5308.
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
