JVC CS-ARS500
JVC CS-ARS650
JVC CS-ARS680
JVC Mobile Entertainment offers a broad new selection of Arsenal Series speakers to appeal to specialist retailers and enthusiasts. The Arsenal Series component speakers CS-ARS500, CS-ARS650 and CS-ARS680 feature an illuminated crossover network and a glass fiber laminated hemp cone.
All Arsenal speakers have a sensitivity of 92dB/Wm. The two-year standard warranty applies to all Arsenal products.
Slim Design
A slim design allows for installation in a wider range of cars. This is enabled by application of neodymium magnets and aluminum frames. The CS-ARS650 and CS-ARS680 include adapters to expand the range of cars where they may be installed. Angle adjustable tweeter expands installation possibilities.
Hemp Fiber
Hemp fiber provides natural mid and high frequency sound, creates a smooth transition between woofer and tweeter crossover frequencies, and is strong and light enough for more power capability and stunning sound quality.
Sophisticated Design–Powerful and High-Grade
A T3 Chassis (Thermal Transfer Technology) transfers heat away from the voice coil to the speaker’s aluminum basket by connecting the neodymium magnet structure to the basket, using a layer of heat transfer silicon. The aluminum basket acts like a radiator for the T3 process, providing the best protection against an overheated voice coil, especially under high current loads. With Radiating Equalizer, the center piece on an Arsenal component driver is connected to the speaker’s T3 structure, and efficiently dissipates heat from inside of the motor structure. Its unique shape design also blends and focuses high-frequency sound waves toward the listener’s ears.
A Solid Neodymium Disc Magnet is unlike conventional magnets, which radiate magnetic force in all directions. The Solid Disc Magnet focuses more magnetic power upwards toward the speaker’s voice coil–creating more power handling and SPL.
CS-ARS680-6″ x 8″/ 5″ x 7″ 2-Way Component Speakers
- 240W Max./80W RMS
- Frequency Response: 35 Hz -30,000Hz
- 6×8″/5×7″ Universal Installation Capability
- Separate Crossover Network
- Glass Fiber + Paper + Hemp Cone Woofer
- Titanium Hard Dome + Silk Edge Tweeter
- Neodymium Magnet (Tweeter)
- High Efficiency T3 Air Vent Cooling System
CS-ARS650-6.5″ 2-Way Component Speakers / CS-ARS500-5″ 2-Way Component Speakers
- 240W Max./80W RMS (CS-ARS650)
- 210W Max./70W RMS (CS-ARS500)
- Frequency Response: 35Hz-32,000Hz (CS-ARS650)
- Frequency Response: 50Hz-32,000Hz (CS-ARS500)
- Universal Mounting Adapter (For CS-ARS650)
Model | Price |
CS-ARS500 | $259.95 |
CS-ARS650 | $279.95 |
CS-ARS680 | $299.95 |
