JMGO O1 UST LED Projector: Big Screen Entertainment for a Reasonable Price
JMGO offers up a UST projector for those with small budgets. Check out what the O1 1080p Ultra-Short Throw LED Projector has to offer.
JMGO 01 LED 1080p HD UST Projector
If you are looking for a big-screen home theater experience, but can’t afford a large screen 4K UHD TV or 4K UHD video projector, the JMGO O1 1080p LED UST projector might be the solution for you. Let’s check out how this projector works and what it offers.
What an Ultra Short Throw (UST) Projector Is
An Ultra-Short Throw Projector (aka UST) incorporates a specially constructed lens assembly that allows images to be displayed from a very short distance. This means instead of placing the projector behind the seating position on a table or ceiling you can place it on a table or shelf within a couple of feet from a screen or wall and project very large images without taking much more space than a large TV. This is also great for those that have small rooms.
JMGO O1 LED UST Projector
How The JMGO O1 LED Projection System Works
The JMGO O1 employs a Tri-Color (aka RGB) LED light source which eliminates the need for a lamp that would have to be replaced on a periodic basis.
The way it works is that one LED emits red light, one green, and one blue. The red, green, and blue light travels through a lens and prism and is then bounced off of a DLP Chip and then to the screen.
One of the biggest advantages of UST projectors is that they can be partnered with special ALR screens which allow you to watch in rooms with a lot of ambient light. The image quality certainly improves as your room gets darker, but it’s a feature that makes UST projectors a better option for people (95% of the population) who don’t want a dedicated projector on their living room ceiling or can’t afford a dedicated home theater room in their home.
We’ve tested a number of ALR screens that will work well with any UST projector including the JMGO O1.
The LEDs in the JMGO O1 provide the light source, but the image information and resolution are provided by an image chip (or chips).
The JMG0 employs a .33-inch DLP imaging chip (aka DMD – Digital Micromirror Device) from Texas Instruments. The chip has 2.1 million pixels (the equivalent of 1080p resolution), which are actually very tiny tilting mirrors.
NOTE: Although the JMGO O1 can accept a 4K resolution input signal, it will be downscaled to 1080p resolution for screen display.
NEC SSL Technologies LED
The JMGO O1 can display a 100-inch size image from a distance of only 10-inches. However, JMGO recommends the 80-inch size for the best quality. This means you can place the projector closer to the screen than 10-inches, saving some space.
JMGO O1 Features
In addition to projecting a 1080p resolution image, here is an overview of additional features that can enhance your home entertainment experience.
Light Output: 800 ANSI Lumens Max. This is lower than most home theater video projectors. The projector is best used in a darkened room (preferably with very little or no light leakage from window blinds or curtains and very low or no lights on).
Color Gamut: NTSC 120%
Contrast Ratio: 5,000:1 (Dynamic)
JMGO O1 MEMC Demo
MEMC Comparison
Refresh Rate: 60Hz with additional MEMC (Motion Estimation, Motion Compensation) processing.
Screen Size Range: 60 to 100-inches.
Projection Distance: 10-inches for 100-inch screen size (.25:1 throw ratio).
Focus: Automatic
Keystone Correction: Automatic or manual (4-point).
Digital Wall Calibration: If you don’t have a screen, the O1 will adjust to your wall color.
Gallery Mode: Display artwork screensavers from a selection of pre-installed images
JMGO O1 LED UST Projector in Game Mode
Low Latency Mode:  Optimizes game controller response time for gameplay.
Audio System: Dynaudio 2-channel stereo system with 2 full-range speakers (7 wpc). 760cc sound cavity.
JMGO O1 Luna OS On-screen GUI
Luna OS
Projector OS: The JMGO O1 features Luna OS with a built-in smart Android system, connecting you to several popular streaming apps. You can also check an external media streamer such as Roku or Fire TV stick.
Input Connections
  • HDMI: 1
  • USB ver 2.0 : 2
  • Ethernet/LAN: 1
Output Connections:
  • HDMI:1 (ARC-enabled)
  • Digital Optical: (1) This allows connection to a compatible external audio system.
JMGO 01 LED UST 1080p HD Projector Rear
Additional Connectivity:
  • Wi-Fi
Bluetooth: Allows music streaming from compatible smartphones and tablets.
Control: Remote control and JMGO Mobile App (Android/iOS
Note: Although Alexa integration is listed on some product information posted by JMGO, I was informed by a representative that this functionality has not been implemented as of the publication date of this article.
Fan Noise: N/A
Dimensions: 12.1 x 9.3 x 3.8-inches (31 x 24 x 10 cm)
Weight:  5 lbs (2.3kg)
Expected Lifespan: 45,000 use hours
Supplied Accessories:
  • Power Cable
  • Remote Control
  • Instruction Manual
  • Warranty Card
Our Thoughts
With 1080p resolution, portability, and very reasonable price the JMGO O1 makes a great first-time projector or for those that have a higher-end projector in their living or media room, it makes a great second projector to use in other rooms in the house.
Pricing and Availability
The JMGO O1 1080p UST LED Projector is available at a suggested price of $1,099.99 on Amazon but may be offered for a lower promotional price.
Note: This projector is named the O1 (letter O), not the number 01.
If you are looking for something a little more higher-end, check out our report on JMGO U2 4K UHD Laser Projector.
Promotional Video
JMGO Factory
JMGO Factory
NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Focal Bathys MG Wireless Headphone in-hand Focal Bathys MG Wireless Headphone in-hand
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
FiiO FX17 IEM FiiO FX17 IEM
Earbuds & In-Ear Headphones
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
Priced at $234.99, the Cleer ARC 3 Gaming Edition comes with a USB-C dongle for low latency wireless gaming.
