Car Amplifiers
JL Audio Slash v3 Car Amplifiers
In 2012, JL Audio is introducing the Slash v3 car amplifiers featuring an all-black look. The patented Class D output circuitry in the monoblocks has been enhanced to deliver 20% more power than the previous generation v2 amplifiers. On-board signal processing includes a parametric equalizer and highly advanced crossover controls.
JL Audio Slash 300/4v3 Car Amplifiers
The companion four-channel amplifier is the 300/4v3, offering 75W x 4 from JL Audio’s patented Absolute Symmetry Class A/B output stage.
All models feature JL Audio’s R.I.P.S. (Regulated Intelligent Power Supply) technology to maintain consistent power over a wide range of load impedances and supply voltages, as well as Advanced Rollback Thermal protection to keep your music playing under the most demanding conditions.
JL Audio Slash 600/1v3 Car Amplifier
Specifications
300/4v3 600/1v3 1200/1v3
Continuous Power:
(RMS method)
11-V – 14.4V @ <0.03% THD+N
4 x 75W @ 1.5 – 4 ohms
2 x 150W @ 3-8 ohms (Bridged)
11-V – 14.4V @ <0.05% THD+N 600W @ 1.5 – 4 ohms 11-V – 14.4V @ <0.05% THD+N 1200W @ 1.5 – 4 ohms
Frequency Response: 5 Hz – 30 kHz
(+0, – 1 dB)
5-250 Hz
(+0, – 1 dB)
5-250 Hz
(+0, – 1 dB)
Damping Factor: >200 @ 4 ohms >500 @ 4 ohms >500 @ 4 ohms
Dimensions (H x W x D): 2.36 x 9.25 x 13.4 in
(60 x 235 x 340 mm)
(60 x 235 x 340 mm)
2.36 x 9.25 x 19.7 in
(60 x 235 x 500 mm)
Availability: Q1 2012 Q1 2012 Q2 2012
MSRP: $649.95/each $699.95/each $1,299.95/each
JL Audio Slash 1200/1v3 Car Amplifier
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
