JL Audio Polaris Ranger Stealthbox Subwoofer System
For the ’04 – ’08 Polaris Ranger
The Polaris Ranger is one of the hottest all terrain utility vehicles designed for work and play and owners know that their side-by-side is capable of some pretty impressive off-road feats, but one major short-coming is its lack of a serious stereo system.
JL Audio’s answer to this problem is a 3-piece Stealthbox design, as rugged as the Ranger itself. The system employs a pair of JL Audio’s legendary 7.7-inch marine-grade coaxials, plus a 10-inch JL Audio marine subwoofer. The kick-panels and the sealed subwoofer enclosure are constructed of 100% fiberglass and texture-coated for maximum durability and to integrate with your Ranger’s design. Add a source unit (which could be as simple as an iPod or your favorite MP3 player) and a four-channel amplifier, and your Ranger will become the ultimate adventure machine.
The JL Audio Polaris Ranger Stealthbox contains one M10W5-SG-TB subwoofer in a sealed enclosure with 250 watt power handling and wired for 4 ohm mono and one pair of M770-CCX-CG-TB Marine Coaxial speakers, each in a separate kick-panel designed to handle 150 watts per channel a final impedance of 4 ohms per channel. A JL Audio four channel amplifier, bridged to three channel mode is recommended to power the system.
JL Audio currently makes more than 111 Stealthbox subwoofer systems to fit a variety of popular automobiles, trucks, and SUVs.
Available now – Suggested Retail Pricing: $1299.95
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
