JL Audio Introduces G & M Series Amplifiers
Miramar, FL–March 6, 2008–JL Audio has introduced the G & M Series Amplifiers and by popular demand, the company has re-rated and renamed the A Series amplifiers for direct comparison to the rating method employed by other manufacturers.
All power ratings for the new G-Series and 2008 M-Series Marine Audio amplifiers are based on the “industry standard” rating method (14.4V supply voltage with less than 1% THD+N, all channels driven).
All the goodness of JL Audio amplification has been left intact. The differential-balanced inputs, killer signal processing features, JL Audio’s unique “never quit” rollback protection circuit, and our super-clean, patented amplifier circuits are still there, delivering the same quality you expect from JL Audio.
Six models are available in the G-Series:
G1300
300 Watt Monoblock Full Range Amplifier
Continuous Power @14.4V:
150W x 1 @ 4 ohm
300W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz-20 kHz
Frequency Response:
10Hz-25 kHz (+0, -1dB)
Dimensions (L x W x H):
9.80 in. x 9.25 in. x 2.50 in
250 mm x 235 mm x 63.5 mm
MSRP: $249.00
Availability: 2nd Quarter, 2008
G1300
150W x 1 @ 4 ohm
300W x 1 @ 2 ohm
THD at Rated Power:
Frequency Response:
MSRP: $249.00
G1700
700 Watt Class D Monoblock Subwoofer Amplifier
Continuous power @ 14.4V:
350W x 1 @ 4 ohm
700W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz — 250Hz (+0, -1dB)
Dimensions: (L x W x H):
11.81 in. x 9.25 in. x 2.50 in.
300 mm x 235 mm x 63.5 mm
MSRP: $429.95
G-MAX
1200 Watt Class D Monoblock Sub Amplifier
Continuous Power @ 14.4 V:
600W x 1 @ 4 ohm
1200 W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz-250 Hz
Frequency Response:
10 Hz — 250 Hz (+0, -1 dB)
15.75 in. x 9.25 in. x 2.50 in.
400 mm x 235 mm x 63.5 mm
MSRP: $599.95
G4500
500 Watt Four-Channel Amplifier
80W x 4 @ 4 ohm per ch.
125W x 4 @ 2 ohm per ch.
THD at Rated Power:
<1% THD, 20 Hz — 20 kHz
Frequency Response:
10 Hz — 25 kHz (+0, – 1dB)
13.80 in. x 9.25 in. x 2.50 in.
350 mm x 235 mm x 63.5 mm
MSRP: $369.95
Availability: 2nd Quarter 2008
G2250
250 Watt Two-Channel Amplifier
Continuous Power @ 14.4V:
80W x 2 @ 4 ohm per ch.
125W x 2 @ 2 ohm per ch.
THD at Rated Power:
<1% THD , 20 Hz — 20 kHz
Frequency Response:
Dimensions: L x W x H):
9.80 in. x 9.25 in. x 2.50 in.
MSRP: $249.95
G6600
600 Watt Six-Channel Amplifier
75 W x 6 @ 4 ohm per ch.
100W x 6 @ 2 ohm per ch.
THD at Rated Power:
Frequency Response:
10 Hz — 25 kHz (+0, -1 dB)
17.70 in. x 9.25 in. x 2.50 in.
450 mm x 235 mm x 63.5 mm
MSRP: $489.95
M-Series Marine Audio Amplifiers:
M2250
250 Watt Two-Channel Marine Amplifier
THD at Rated Power:
Frequency Resonse:
MSRP: $269.95
M6600
600 Watt Six-Channel Marine Amplifier
75W x 6 @ 4 ohm per ch.
THD at Rated Power:
Frequency Response:
10 Hz — 25 kHz (+0, -1dB)
MSRP: $539.95
M1700
700 Watt Class D Monoblock Marine
Subwoofer Amplifier
350W x 1 @ 4 ohm
700W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz — 250 Hz
Frequency Response:
MSRP: $479.95
M4500
500 Watt Four-Channel Marine Amplifier
80W x 4 @ 4 ohm per ch/
THD at Rated Power:
Frequency Response:
MSRP: $409.95
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
