JL Audio Evolution ZR 800: The Ultimate Midbass Power Trip
With more vehicles offering large door speaker locations, the time is right for a superb 8-inch component woofer that can dig deep and deliver world-class midbass impact and definition. New from the ground up, and incorporating many technologies borrowed from JL Audio’s subwoofer designs, the ZR800-CW will quickly become a favorite for those who seek the ultimate mobile audio experience.
A proprietary cast alloy frame supports the ZR800-CW’s DMA-optimized motor, FEA-optimized spider, injection-molded cone body and a Santoprene™ surround. Another important aspect of this speaker’s capabilities centers on its oversized 1.75-inch voice coil (cooled via JL Audio’s Patented Elevated Frame Technology), which enables the ZR800-CW to comfortably handle power while retaining excellent linearity and dynamic stability. For optimal performance, we recommend that they be used in a tri-amplified system design with dedicated amplifier channels and active filtering.
ZR800-CW’s are built in JL Audio’s Miramar, Florida factory and are sold individually with a classy mesh grille to match our ZR component systems.
Exceptional Infinite-Baffle Midbass Performance
  • Exceptional Infinite-Baffle Midbass Performance, Effective Down to 40 Hz
  • High Power Handling, Long Excursion Design
  • Shallow Mounting Depth
  • Perfect for Newer Cars with Large Door Locations
  • Precision-Built in U.S.A
ZR800-CW
  • Nominal Diameter: 8.0 in. (200 mm)
  • Continuous Power Handling: 125 W
  • Xmax: 0.31 in. (7.9 mm) one-way, linear
  • Impedance: 4 ohm
  • Mounting Depth: 3.39 in. (86 mm)
  • MSRP: $229.95 ea.
  • Availability: April, 2008
  • Made in the USA
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
