Car Subwoofers
JL Audio 12TW3 and 10TW3 Car Subwoofers
JL Audio announced new TW3 car subwoofer drivers, which deliver a powerful combination of shallow mounting depth and amazing excursion capability, available in 12-inch (12TW3) and 10-inch (10TW3) sizes.
JL Audio's patented thin-line woofer technology compresses the architecture of the TW3's using a “concentric tube” structure built into the injection-molded cone body. This structure supports the voice coil and a full annular spider, while permitting the placement of the large motor structure further forward in the speaker than with conventional designs.
The JL Audio TW3's are optimized for small enclosures and offer the company's tab-ear mounting design to maximize cone area within their mounting footprints.
JL Audio 12TW3 Car Subwoofer - Side
According to Manville Smith, JL Audio's V.P. of Marketing, “These subwoofers give installers the ability to add deep, powerful and accurate bass in more applications than ever before, at prices that are right in the mainstream.”
Features:
  • Very shallow mounting depth (3.25 / 3.50 Inches)
  • No pole vent: permits mounting close to rear wall of enclosure.
  • Very small sealed enclosure volume requirements
  • Very long linear excursion capability (0.60 In / 15.2 mm, one-way)
  • DMA-optimized motor designs
  • Patented “concentric tube” architecture
  • Patented “floating cone attach method” technology
  • Cast alloy frame
  • Injection molded, mica-filled polypropylene cone
  • Rubber surround
  • Aluminum-alloy dust cap and rear cap with JL Audio logo
  • Precision-built in USA at JL Audio's Miramar, Florida factory
JL Audio 12TW3 Car Subwoofer - Back
Specifications
10TW3 12TW3
Nominal Diameter: 10-inch (250 mm) 12-inch (300 mm)
Recommended Power Range: 125 – 400 Watts 125 – 400 Watts
Xmax: 0.60 in (15.2 mm) one-way, linear 0.60 in (15.2 mm) one-way, linear
Impedance: Dual 4 ohm Dual 4 ohm
Rec. Sealed Enclosure: 0.50 cu.ft. (14.3 l) 0.75 cu.ft. (21.3 l)
Mounting Depth: 3.25 in (83 mm) 3.5 in (89 mm)
Availability: Second Quarter 2012 Second Quarter 2012
MSRP (USD): $349.95 each $399.95 each
Epson QS100 UST Projector Front Lifestyle
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
