JBL WR2.4 Wireless Headphones
The new JBL WR2.4 wireless over-ear headphones offer untethered listening freedom up to 100 feet (30 meters) away from the base station. These headphones should not be confused with Bluetooth headphones, which stream directly from smartphones. Instead, the base station must be connected to your home stereo via regular RCA audio cable, which is included. The base station then streams music using 2.4 GHz wireless technology to the headphones.
Since the headphones require power to receive a wireless audio signal, they must be re-charged by docking them back on the base station. JBL claims eight hours of continuous listening.
The JBL WR2.4 headphones are designed for comfort with generously sized padded cups and a fully adjustable headband. JBL says these wireless headphones can be worn for extended periods without fatigue.
JBL engineers have designed the WR2.4 headphones with semi-closed back acoustics for naturally enhanced sound quality throughout their 18 Hz to 20 kHz sound range. The uncompromising 2.4 GHz digital bandwidth ensures reception untainted by transmission noise, and the 32-ohm impedance enables a wide range of listening volumes.
JBL WR2.4 headphones come with two rechargeable AAA batteries, a pick-up-and-go charging cradle and power adapter; and a 3.5 mm stereo to dual RCA audio cable for connecting your audio system to the transmitter base.
Pricing and Availability
The JBL WR2.4 Wireless Headphones are available now for $99.95.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
