JBL Synthesis SDA-8300 & SDA-4600 Multichannel Network Amplifiers
JBL Synthesis SDA-4600 Amplifier
HARMAN’s JBL Synthesis has released the SDA-8300 and SDA-4600 multichannel network power amplifiers, eight and four-channel models that offer Ethernet networking connectivity, high power output and many additional benefits. The 8-channel SDA-8300 delivers 300-watts into 8 ohms and the 4-channel SDA-4600 provides 600-watts into 8 ohms.
The new high-performance installation amplifiers are designed to work hand in hand with other JBL Synthesis electronics. Both models offer networked digital audio and control connectivity to JBL Synthesis surround sound preamplifiers, equalizers and other components via the amplifiers’ primary and secondary Ethernet transport ports. The SDA-8300 and SDA-4600 connect to a JBL Synthesis SDEC-4500 equalizer via an Ethernet cable.
JBL Synthesis SDA-4600 Amplifier Back
SDA-4600
Though powerful, the SDA-8300 and SDA-4600 are compact, measuring just 3.5″ high x 19″ wide x 14.25″ deep, and weigh under 25 lbs. Their high power-to-weight performance is made possible by HARMAN’s proprietary DriveCore Class D, PWM technology that combines the amplifier driver stage into the power output stage along with additional audio-signal functions, yet is about the size of a postage stamp. DriveCore also reduces power consumption and yields much more energy-efficient operation, and enables the design of amplifiers that save space and weight and generate far less heat in an equipment rack.
JBL Synthesis SDA-8300 Amplifier Back
SDA-8300
The JBL Synthesis SDA-8300 and SDA-4600 feature front-panel display and LED indicators that provide ready indication of key functions. In addition to digital audio connectivity and control, the amplifiers’ networking connectivity provides continuous load monitoring and other diagnostics, and both models offer comprehensive DSP capablities such as built-in crossovers, output limiting, input and output EQ and additional feature that enable the amps’ performance to be perfectly tailored to any custom installation and room. The SDA-8300 and SDA-4600 incorporate HARMAN’s exclusive Power Factor Corrected (PFC) universal power supply that is designed to deliver maximum power in any country and their universal AC input accepts voltages from 100 – 240 VAC, 50/60Hz. Both amplifiers feature a black anodized front panel that perfectly matches the styling of other JBL Synthesis components.
Availability
The JBL Synthesis SDA-8300 and SDA-4600 Multichannel Network Amplifiers are now shipping.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
