JBL Synthesis SDA-1700 Subwoofer Amplifier: CEDIA 2022
The rack mountable JBL Synthesis SDA-1700 Class D Subwoofer Amplifier is designed to work with the SSW-4 in-wall passive subwoofer.
There are very few companies that make loudspeakers for commercial movie theaters as well as home cinemas. JBL is one such brand, and their JBL Synthesis range represents their state-of-the-art components and loudspeakers for a dedicated home theater space.
A complete JBL Synthesis home theater system includes in-wall or stand-alone loudspeakers and subwoofers, amplifiers, preamps and surround sound processors. Depending on the configuration, a complete JBL Synthesis home theater system can range from $10K to $250,000.
The Synthesis subwoofer models are all passive designs requiring external amplification and that adds an additional expense to any home theater system.
JBL Synthesis SDA-1700 Sub Amp Front Rear
When the new JBL Synthesis SDA-1700 Class D subwoofer amplifier starts shipping soon, customers will have a more affordable entry point.
The “entry-level” (not really) JBL Synthesis subwoofer/amp combo will set you back $2,420.
Priced at $1,320, the SDA-1700 provides a 2RU rack mountable amplifier solution designed to power the JBL Synthesis SSW-4 dual 8-inch in-wall passive subwoofer ($1,100) — delivering 350W to a single SSW-4 or 700W to a pair.
JBL Synthesis SSW-4 In-Wall Passive Subwoofer
For the ultimate home theater system, the SDA-1700 and SSW-4 can be paired with JBL Synthesis’ SDR-38 A/V Receiver and SCL series in-wall and in-ceiling loudspeakers.
Tip: The SDA-1700 can also be used with systems using the JBL C82W In-wall Subwoofer.
The SDA-1700 includes convenient front-panel volume control, while the rear-panel controls include crossover, phase, single-band PEQ (Parametric Equalizer), and module EQ (Equalizer). The rear panel controls allow for fine-tuning by custom installers.
JBL Synthesis SDA-1700 Subwoofer Amplifier Angle
SDA-1700 Core Features
  • Low distortion and Low noise.
  • Short-circuit Protection.
  • Over-current protection.
  • Over-temperature compensation.
  • Signal sensing for automatic turn-on and turn-off.
  • One set of analog audio inputs.
  • Two dual banana-compatible speaker connections.
  • Housed in a 2RU chassis, the unit ships with rack ears for mounting in traditional enclosure racking systems.
JBL Synthesis SDA-1700 Rear Closeup
SDA-1700 Specifications
  • Amplifier Type: Class D
  • Power Output: (RMS) 700 Watts @ 4 ohms, (Peak Power) 1500W
  • Rated Impedance: 8 Ohms
  • Low Pass Crossover Range: 50-150Hz
  • THD+N at Rated Output Power: < 1%
  • Signal-to-Noise Ratio to 1W: > 65dBA
  • EQ1 Settings: Specific for JBL Synthesis SSW-4 In-wall Subwoofer
  • EQ2 Settings: Specific for JBL C82 In-wall Subwoofer
  • Dimensions (HDW): 3.50 x 11.04  x 17-inches (88.90 x 280.3 x 431.8 mm)
  • Weight: 14 lbs (6.35Kg)
JBL Synthesis SDA-1700 Subwoofer Amplifier Internal
From Jim Garrett, Senior Director, Product Strategy and Planning, HARMAN Luxury Audio: “With its dedicated equalization and protection circuitry, the SDA-1700 provides installers with a tailor-made, lower-cost solution for optimizing the performance of SSW-4 in-wall subwoofer modules. Furthermore, the amplifier pairs perfectly with an SDR-38 AVR used to power our SCL series architectural loudspeakers in a complete JBL Synthesis home theater system.”
JBL Synthesis SDA-1700 Subwoofer Amplifier Front
Availability & Pricing
The JBL Synthesis SDA-1700 is available for a manufacturer-suggested retail price of $1,320 via Authorized JBL Synthesis dealers.
Other compatible products available through Authorized Dealers include:
For more information: jblsynthesis.com
Theory Audio Design Unveils Next Generation Amplified Loudspeaker Controllers: CEDIA 2022
Theory Audio Design’s Iws12-6 & Iws12-9 In-Wall Subwoofers Are Going To Shake Your Foundation: CEDIA 2022
Pro Audio Technology’s SR-2408iw Loudspeakers Deliver Big Sound In Tight Quarters – CEDIA 2022
Origin Acoustics Announces New Speakers And Subwoofers: CEDIA 2022
See More New Products from CEDIA 2022
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
