Earbuds & In-Ear Headphones
JBL Synchros Reflect BT In-Ear Headphones
JBL Synchros Reflect BT in-ear headphones
JBL introduced two in-ear sport headphones for under $100 in both a wired and wireless Bluetooth version. The new JBL Synchros Reflect and JBL Synchros Reflect BT earphones feature Freebit ergonomic ear tips, while its reflective colored cable makes you more visible when you run in low light situations.
JBL Synchros Reflect in-ear headphones combine quality sound with secure fit and reflective cables. Freebit ear tips, designed to stay put through all your reps, twists and turns, gently but firmly lock into your ears and channel the sound to you. The distinctive, reflective colored cord looks out for you, making you more visible in low light situations. A customizable extension cable lets you set the length so you can wear your player or smartphone wherever is best for you to stay plugged in and in the zone. Built-in magnets keep the earpieces on stand-by when not in use. Wrap them around your neck and watch them click together; no more loose cables getting caught on your sport clothing. Take calls, control tracks and adjust volume with rugged, sweat-proof in-line controls. Choose iOS for Apple devices, or universal for compatibility with most others. And underneath it all, there’s that powerful JBL bass and clear vocals, keeping you pumped-up and on track.
The JBL Synchros Reflect BT in-ear headphones with Bluetooth keeps you unfettered, with freedom from wires and up to 5 hours of your favorite soundtracks. JBL Synchros Reflect BT’s rugged design and ergonomic form factor are fully suited to a driven, athletic lifestyle. The Synchros Reflect BT also includes Freebit ear tips that fit with comfort and stability so your headphones are never a distraction. The distinctive, reflective colored cord is also a staple for these headphones and makes you more visible in low light situations, while the unique in-line sliding clasp allows adjustment of the cable length to keep your remote control/mic at hand but never in the way. And when you’re not listening, just wrap the earpieces around your neck; built-in magnets click together and keep them on stand-by. These sweat-proof headphones take whatever you can dish out and keep on doing what they do best: deliver quality JBL sound from their premium 8.5 mm drivers to keep you motivated and in the zone.
Pricing and Availability
JBL Synchros Reflect → $59.95
JBL Synchros Reflect BT → $99.95
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
In-Wall Speakers
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
