In-Wall Speakers
JBL Stage 2 & Stage XD Series Architectural Loudspeakers Unveiled: CEDIA 2022
The new JBL Stage 2 in-wall/in-ceiling and Stage XD all-weather loudspeakers are surprisingly affordable.
JBL Stage 260W In-wall Speaker and Stage XD All-Weather Speaker
The CI category has come out of the pandemic with a lot of momentum and it has become clear that loudspeaker brands that were already strong players in the segment are being aggressive with new in-wall, in-ceiling, and outdoor loudspeaker models.
At the 2022 CEDIA Expo, Origin Acoustics, Focal, KEF, Theory Audio, Pro Audio Technology, and Harman/JBL showed off dozens of new models in the respective categories.
In this article, we provide an overview of the new JBL Stage 2 Architectural Series and Stage XD Series All-Weather Loudspeakers. The new speaker line consists of eight models designed for configurations for in-wall and in-ceiling installations as well as two models suitable for outdoor use.
The JBL Stage 2 Architectural Series Loudspeakers are the company’s most affordable in-wall/in-ceiling models. They’re designed to be visually inconspicuous while delivering clear and accurate sound for indoor music or home theater applications.
JBL Stage 280W In-Wall Speaker
Shared features include:
  • Rigid baffle design with acoustic smoothing provides improved transducer integration, while HARMAN’s target curve acoustic performance delivers smooth, accurate sound over a large listening area.
  • On the woofer side of things, polycellulose cone woofers, premium air-core inductors, and mylar cap capacitor crossover network components are used.
  • The Stage 2 Architectural Series features paintable, Zero Bezel magnetically attached grilles. This provided a contemporary look that blends easily into any décor, while the XL-2 Mounting System allows for quick installation and is compatible with up to 2-inch/50-millimeter material thickness.
  • The Stage 260CSA and 280CSA feature a square footprint and a baffle with the drivers  positioned at a 15-degree angle, allowing the em to focus the sound at the listening position. CSA stands for “Ceiling Squared Angle”.
  • Preconstruction brackets are available for all models, and square grille accessory kits are available for the Stage 260C, Stage 280C, and Stage 260CDT round in-ceiling models.
JBL Stage 260CSA In-ceiling Square Angled Speaker
Here is a list of models in the Architectural Series with some specifications and prices. The speakers can be purchased through authorized Harman/JBL dealers.
Tip: All speakers in the following chart have an 8-ohm impedance. Tap on the model number to dig deeper into additional product features and specifications not shown.
ModelTweeter WooferCrossover FrequencyFrequency Response
(on-axis -6dB)
Price
(ea.)
Stage 260W1″ (25mm) Aluminum dome with High-Definition Imaging (HDI™) Waveguide6.5″ (165mm) Polycellulose cone woofer1900Hz50Hz-25kHz $150
Stage 280W1″ (25mm) Aluminum dome with High-Definition Imaging (HDI™) horn8″ (200mm) Polycellulose cone woofer1700Hz42Hz-25kHz $225
Stage 250WL1″ (25mm) Aluminum dome with High-Definition Imaging (HDI™) WaveguideDual 5.25″ (130mm) Polycellulose cone woofers2100Hz52Hz-25kHz $250
Stage 260C1″ (25mm) Aluminum dome with Acoustic Lens6.5″ (165mm) Polycellulose cone woofer3000Hz50Hz-25kHz$150
Stage 280C1″ (25mm) Aluminum dome with Acoustic Lens8″ (200mm) Polycellulose cone woofer3400Hz42Hz-25kHz$225
Stage 260CDTDual 3/4″ (20mm) Aluminum dome with Acoustic LensDual VC 6.5″ (165mm) Polycellulose cone woofer2900Hz50Hz-25kHz$175
Stage 260CSA1″ (25mm) Aluminum dome with Acoustic Lens6.5″ (165mm) Polycellulose cone woofer2800Hz50Hz-25kHz$150
Stage 280CSA1″ (25mm) Aluminum dome with Acoustic Lens8″ (200mm) Polycellulose cone woofer2900Hz42Hz-25kHz$225
Stage XD All-Weather Speakers
JBL Stage XD Outdoor Speakers
JBL Stage XD Outdoor All-Weather Speakers
In addition to the Stage 2 Architectural speakers, the JBL Stage XD Series takes things outdoors.
The Stage XD Series are all-weather loudspeakers that combine patented JBL acoustic technologies with IP67-rated weatherized waterproof enclosures to bring JBL sound outdoors for year-round entertainment.
One distinguishing feature of the Stage XD is that they are designed to be repairable.
The XD-5 and XD-6 are designed for outdoor locations where protection from the environment is needed. However, their stylish design and mounting flexibility also make them equally at home indoors for a variety of applications.
JBL Stage XD Outdoor Speakers with Grille on and off
JBL Stage XD-6
Wall mounts, Zero Bezel magnetically attached grilles, and a rotatable logo are provided for horizontal and vertical applications. The speakers are offered in both black and white finishes.
Just as with the previous speakers, contact an authorized dealer for purchase details
Tip: Tap on the model number to dig deeper into product features and specifications.
ModelStage XD-6Stage XD-5
Speaker Type2-Way 2-Way
Weatherproof RatingIP67IP67
Tweeter1″ (25mm) Aluminum dome with High-Definition Imaging (HDI™) waveguide1″ (25mm) Aluminum dome with High-Definition Imaging (HDI™) waveguide
Woofer6.5″ (165mm) Polypropylene Graphite Filled Cone Woofer5.25″ (130mm) Polypropylene Graphite Filled Cone Woofer
Impedance4 ohms4 ohms
Sensitivity (2.83V@1m)88dB86dB
Recommended Amplifier Power  (RMS)20-100W20-100W
Frequency Response (-6dB on Axis)55Hz-25kHz75Hz-25kHz
Crossover Frequency2500K2500K
Operating Temperature32° F (0° C) to 113° F (45° C)32° F (0° C) to 113° F (45° C)
Price (Pair)$599$449
According to Jim Garrett, Senior Director, Product Strategy and Planning, HARMAN Luxury Audio: “Designed to be heard and not seen, the Stage 2 Architectural Series provides high-performance sound at an affordable price point to meet the budget requirements of any installation. And by offering one of the highest levels of ingress protection available, not only are Stage XD Series loudspeakers built for prolonged exposure to harsh conditions but they’re also designed to come apart and undergo repair in case of damage, instead of finding their way to the landfill.”
Brian Mitchell, eCoustics Founder got a brief listen to some of these models during a Pre-CEDIA tour at Harman Headquarters in Northridge, CA. He said, “Audio shoppers shouldn’t confuse JBL’s low price points with low quality. The JBL Architectural Series in-wall/in-ceiling speakers can conceal a true Dolby Atmos speaker system in your room for under $2,000. Meanwhile, the Stage XD all-weather speakers can throw a long soundstage while maintaining clarity that’s ideal for backyard events.”
Focal Unveils 100-T Series In-ceiling and Outdoor Speakers: CEDIA 2022
JBL Synthesis SDA-1700 Subwoofer Amplifier: CEDIA 2022
Theory Audio Design’s Iws12-6 & Iws12-9 In-Wall Subwoofers Are Going To Shake Your Foundation: CEDIA 2022
Pro Audio Technology’s SR-2408iw Loudspeakers Deliver Big Sound In Tight Quarters – CEDIA 2022
Origin Acoustics Announces New Speakers And Subwoofers: CEDIA 2022
See More New Products from CEDIA 2022
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
In-Wall Speakers
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
