Preview: JBL Unveils Stage 2 Speaker Line for 2024
JBL’s new modern and affordable approach to hi-fi and home theater pairs Stage 2 loudspeakers with new MA series A/V Receivers in matching white or black finishes.
JBL Stage 2 Loudspeakers (2024 models) in Latte
With 75 years of experience in both professional and home audio, JBL has a storied tradition in audio innovation, which bears out in their latest product introductions, the MA AVR and Stage 2 series of components and loudspeakers.
JBL’s strategy is to market the MA Series AVRs and Stage 2 speakers as an expandable stereo or home theater system combination — at a much more affordable price point.
Tip: For those wondering, MA stands for “Modern Audio” and these new models look nothing like the retro JBL speakers the company has been known for, such as their Classic Series and L100.
Whether users are starting with a basic two-channel system, upgrading from a soundbar, or looking to build a high-end home theater setup featuring 8K HDMI video, Dolby Atmos immersive sound, and DTS:X, the Stage 2 speakers and MA Series AVR product range can be scaled to meet those needs.
The performance profile of each model has been optimized both individually and as a system. This gives users the freedom to create the setup they want without sacrificing sound quality.
JBL Stage 2 Loudspeakers (2024 models) in Espresso Finish
JBL Stage 2 Loudspeaker line in Espresso Finish
JBL Stage 2 Loudspeaker line consists of 8 speakers grouped as follows:
  • Floorstanding Models: 260F and 280F ($999/$1199)
  • Bookshelf Models: 240B and 250B ($299/$399)
  • Center Channel Model: 245C ($449)
  • Dolby Atmos Height Module: 240H ($499)
  • Powered Subwoofers: 200P and 220P ($499/$599)
All of the speakers were designed and engineered at JBL’s Acoustic Engineering Center of Excellence in Northridge, California.
Gen Z Chimes in on JBL’s new Receivers and Speakers.
All of the speakers (except for the subwoofers) incorporate JBL’s High Definition Waveguide (HDI) technology, Anodized Aluminum Cone tweeters, and Polycellulose woofers. In addition, to make them easy on the eyes (you don’t want your speakers to distract from your listening enjoyment) they are all offered in an Espresso or Latte woodgrain finish.
The two subwoofer models come with either a 10 or 12-inch Polycellulose driver, supported by dual rear-firing ports and built-in amps. Controls for Auto Power, Crossover, Level, and Phase are available on the rear panel. The subwoofers are also offered in the same Espresso or Latte finish.
JBL Stage 2 Floorstanding Loudspeakers in Latte Finish Lifestyle
Floorstanding Speaker Comparison
Stage 260FStage 280F
Price$999/pair$1,199/pair
Speaker Type2-Way Floorstanding2.5-Way Floorstanding
Low-Frequency Driver2 x 6.5-inch (165mm) Polycellulose Ribbed Cone2 x 8-inch (200mm) Polycellulose Ribbed Cone
High-Frequency Driver1-inch (25mm) Anodized Aluminum 1-inch (25mm) Anodized Aluminum
WaveguideNext Generation HDI™Next Generation HDI™
Recommended Amplifier Power20-225W 20-225W
Frequency Response ±6dB40Hz-25kHz 33Hz-25kHz
Sensitivity @ 1M, 2.83V90dB91dB
Nominal Impedance6 Ohms6 Ohms
Crossover Frequencies1.3kHz/1.7kHz 1.1kHz/2.1Khz
Enclosure TuningBass Reflex via Dual Flared Racetrack Rear-Firing Tuned Ports Bass Reflex via Dual Flared Racetrack Rear-Firing Tuned Ports
Connections5-way Binding Posts for Amplifier connection
5-way Binding Posts for Height Speaker connection
FinishEspresso or Latte Espresso or Latte
Dimensions (HWD)40.8 x 12.2 x 14.3 inches
(1036 x 310 x 362 mm)
43.8 x 14.1 x 16.5 inches (1113 x 357 x 420 mm)
Dimensions (HWD – w/o Base)40.8 x 7.9 x 13.9 inches
(1036 x 200 x 354 mm)
43.8 x 9.5 x 16.1 inches
(1113 x 241 x 409 mm)
Net Weight43.3 lbs. (19.5kg)55.2 lbs. (25.1 kg)
Shipping Weight53.1 lbs. (24.1kg) 67.5 lbs. (30.6kg)
Shipping Units of Measure:EachEach
JBL Stage 2 Bookshelf Loudspeakers in Latte Finish Lifestyle
Bookshelf, Height, and Center Speaker Comparison
240B250B240H245C
Price$299.99/pair$399.99/pair$299.99/pair$399.99
Speaker Type2-Way Bookshelf 2-Way Bookshelf 2-Way Height Surround Sound2.5-way Center Channel
Low-Frequency Driver1 x 4.5-inch (114mm) Polycellulose Ribbed Cone  1 x 5.25-inch (130mm) Polycellulose Ribbed Cone 1 x 4.5-inch (114mm) Polycellulose Ribbed Cone4 x  4.5-inch (114mm) Polycellulose Ribbed Cone
High-Frequency Driver1-inch (25mm) Anodized Aluminum1-inch (25mm) Anodized Aluminum1-inch (25mm) Anodized Aluminum1-inch (25mm) Anodized Aluminum
WaveguideNext Generation HDI™Next Generation HDI™Next Generation HDI™Next Generation HDI™
Recommended Amplifier Power20-125W 20-150W 20-150W 20-150W
Frequency Response ±6dB53Hz-25kHz 50Hz-25kHz 85Hz-25kHz55Hz-25kHz
Sensitivity @ 1M, 2.83V85dB86dB87dB 91dB
Nominal Impedance6 Ohms6 Ohms6 Ohms6 Ohms
Crossover Frequencies1.4Khz 1.7Khz 1.6kHz 1.3kHz/2.0kHz
Enclosure TuningBass Reflex via Rear-Firing Flared Tuned PortBass Reflex via Rear-Firing Flared Tuned PortSealed Bass Reflex via Dual Rear-Firing Tuned Ports
Wall MountIntegratedIntegratedIntegratedNot Applicable
Connections5-way Binding Posts5-way Binding Posts5-way Binding Posts5-way Binding Posts
FinishEspresso or Latte Espresso or Latte Espresso or Latte Espresso or Latte
Dimensions (HWD)10.7 x 6.9 x 8.5 inches
(272 x 175 x 217 mm)
12.6 x 7.9 x 9.5 inches
(321 x 200 x 241 mm)
6.9 x 7.1 x 10.6 inches
(176 x 180 x 270 mm)
6.1 x 29.1 x 8.5 inches
(156 x 740 x 217 mm)
Net Weight10.1 lbs
(4.6 kg)
12.4 lbs
(5.6 kg)
7.6 lbs
(3.5 kg)
26.4 lbs
(12.0 kg)
Shipping Weight22.9 lbs
(10.4 kg)
30 lbs
(13.6 kg)
18.8 lbs
(8.5 kg)
32.2 lbs
(14.7 kg)
Shipping Units of Measure:PairPairPair Each
Subwoofer Comparison
200P220P
Price$499.99$599.99
TypePowered SubwooferPowered Subwoofer
Low-Frequency Driver10-inch Polycellulose Ribbed High Excursion 12-inch Polycellulose Ribbed High Excursion
Amplifier Power150W RMS
(300W Dynamic)
250W RMS
(500W Dynamic)
Frequency Response ± 6dB 28Hz-150Hz26Hz-150Hz
Crossover Frequencies50Hz-150Hz (variable) 24dB/octave50Hz-150Hz (variable) 24dB/octave
Crossover Controls35Hz-150Hz 35Hz-150Hz
Other ControlsAuto Power, Crossover, Level, Phase Auto Power, Crossover, Level, Phase
InputsOne (1) Line-Level LFE InputOne (1) Line-Level LFE Input
Enclosure TuningBass-Reflex via Dual Rear-Firing Tuned Ports Bass-Reflex via Dual Rear-Firing Tuned Ports
Power Requirements120V, 60Hz (US) 220-230V, 50/60Hz (EU)120V, 60Hz (US) 220-230V, 50/60Hz (EU)
Power Consumption<0.5W (standby) / 205W/1.6A (max – 230V) / 205W/3.15A (max – 120V) <0.5W (standby) / 205W/1.6A (max – 230V) / 205W/3.15A (max – 120V)
FinishEspresso or LatteEspresso or Latte
Dimensions (HWD)14.2 x 13.8 x 15.2 inches
(361 x 350 x 385 mm)
16.4 x 15.9 x 17.5 inches
(416 x 405 x 444 mm)
Net Weight31.8 lbs
(14.4 kg)
41.2 lbs
(18.7 kg)
Shipping Weight40.3 lbs
(18.3 kg)
51.4 lbs
(23.3 kg)
JBL Stage 2 200P Subwoofer White Back
JBL Stage 200P Subwoofer Rear (has identical rear inputs/ports to 220P)
Initial Impressions
JBL’s Stage 2 loudspeakers offer an affordable solution that incorporates some of the design and technology features from JBL’s higher-end speaker products at an affordable price point.
In addition, the Stage 2 speakers are designed to complement JBL’s MA series affordable A/V Receiver line
For those starting from scratch, it can be a daunting task to setup a home theater system. JBL’s new affordable product lines now make it possible to setup a 5.1 home theater system for under $2,000. Or max out the budget with the top models and immerse yourself in a 9.2.2 Dolby Atmos system for as much as $5,249.
JBL Stage 2 Home Theater Speaker System Lifestyle
JBL Stage 2 Home Theater Speaker System (220P, 280F, 240H, 245C and MA9100HP AVR)
Pricing & Availability
The JBL Stage 2 Series Loudspeakers are priced as follows:
  • 280F: $1,199/pair per pair (floorstander)
  • 260F: $999 per pair (floorstander)
  • 250B: $399 per pair (bookshelf)
  • 240B: $299 per pair (bookshelf)
  • 240H: $299 per pair (height)
  • 245C: $399 each (center)
  • 200P: $499 each (subwoofer)
  • 220P: $599 each (subwoofer)
Tip: Optional Stands for 240B and 250B bookshelf speakers (FS): $249 per pair
The speakers and stands can be purchased through JBL.com, authorized JBL Dealers, and other approved outlets.
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Bang & Olufsen turns 100 with the Beolab 90 Titan Edition—a $200,000+ statement in aluminum and ego that proves audiophile excess is alive and...
At $329, JBL’s Tour PRO 3 wireless earbuds combine dual drivers, adaptive noise cancellation, LDAC support, and a touchscreen Smart Charging Case to challenge...
