JBL Showcases Expanded JBL Performance Series Lineup at EHX Fall 2006
15 November 2006
FOR IMMEDIATE RELEASE
WOODBURY, NY — JBL has significantly expanded its JBL Performance Series lineup of home theater systems and distributed audio solutions to include a much wider variety of loudspeakers, subwoofers and system packages, and to accommodate a broader range of custom-installation requirements.
The JBL Performance Series, which is showcased at JBL’s EHX Fall 2006 exhibit at the Long Beach Convention Center, Long Beach, CA, Booth 435 (November 15 — 17, 2006), encompasses an extensive selection of turnkey, high-end, complete custom-installation home theater audio systems, and a variety of distributed audio speakers. The Series offers a choice of multichannel home theater and distributed audio solutions, all designed to provide unsurpassed sonic realism, control flexibility and ease of use while integrating seamlessly into the home environment.
A variety of loudspeakers, including in-wall speakers and subwoofers, on-wall and stand-mount models, outdoor speakers, powered subwoofers, and additional models, is available. All the speakers are constructed using premium-quality JBL drivers and components to deliver exceptional clarity, detail, dynamic impact and tonal accuracy over a wide listening area.
All JBL Performance Series systems include the AV1 Surround Processor/System Controller and AVA7 7-Channel Power Amplifier, both engineered to deliver state-of-the-art sound and offer versatile connection options with source components and high-definition-display devices.
JBL Performance Series Loudspeakers
The JBL Performance Series offers an extremely wide range of loudspeakers to accommodate virtually every custom-installation home entertainment requirement. Following is an overview of selected models within the JBL Performance Series loudspeaker lineup.
The on-wall models in the JBL Performance Series include the Performance PT800 tower loudspeaker, Performance PS1400 subwoofer, and Performance PC600 center channel. The speakers’ modular design allows the PT800 tower to be stacked atop the PS1400 subwoofer, mounted separately on a wall, or installed on optional available stands, providing maximum installation flexibility in a wide variety of home theater configurations and room sizes. All the speakers utilize a unique shallow-profile enclosure that allows them to occupy a minimum of floor space and be mounted close to a wall, and all models are constructed using professional-quality JBL drivers and components.
The Custom Series P81 and P941 in-wall speakers are ultimate-performance designs that utilize pure-titanium tweeters, and woofers and midrange drivers made from an advanced-technology aluminum/ ceramic multilayer diaphragm material. This material is far more rigid and lightweight than other types of cone materials, enabling it to deliver extraordinary resolution and sonic accuracy. The P81 and P941 also include front-panel listener-axis, high-frequency-contour, high-frequency-level and low-frequency boundary-compensation controls, which allow precise sonic tailoring in any installation.
The Specialist Series offers exceptional in-wall and in-ceiling loudspeaker performance, incorporating pure-titanium-dome tweeters and aluminum-cone woofers to deliver superlative clarity and a smooth tonal balance. The tweeters are housed in a swivel-mounting system that is designed for maximum imaging and clarity, and enables them to be aimed for optimum sound distribution in any installation. Six models, including the SSLCR dual-woofer speaker, are available; the SSLCR can be mounted horizontally or vertically, facilitating its use as the center channel, or as the main and surround channels of a home theater system.
The Integrator Series includes a total of six in-wall and in-ceiling models that offer outstanding value and sound quality, thanks to their use of titanium-laminate swivel-mounted dome tweeters and titanium-laminate cone woofers. All Integrator Series and Specialist Series models are paintable and designed for ease of installation in both new homes and existing rooms.
In addition to the PS1400, available subwoofers include the HTPS400 (12-inch woofer, built-in 1000-watt amplifier), which features a compact enclosure that enables it to be readily placed in a variety of room locations; the PS10SW (10-inch woofer, 150 watts); the PS12SW (12-inch woofer, 250 watts); and the SS88IWS, which can be mounted between standard 16-inch wall studs.
The JBL Performance Series AV1 is a high-performance, software-upgradeable 7.1-channel surround processor/system controller that is designed for total ease of operation; it utilizes advanced digital technologies to achieve the highest possible resolution and fidelity. The AV1 is compatible with popular surround sound decoding formats and incorporates exclusive 7.1 Logic 7 processing for enhanced surround sound realism. The AV1 offers versatile connection options, including high-bandwidth, HDTV-compatible component-video switching, multiple digital and analog audio and video inputs and outputs, and multiple RS-232 ports for facilitating integrated system operation.
The AVA7 7-channel power amplifier delivers 125 watts into each channel (into 8 ohms, <0.03% THD), to easily re-create, in even large listening environments, sound levels equal to those of the original performances. The AVA7 is designed for superb sound quality in every respect, with special attention paid to minimizing the number of components in the audio-signal path to achieve extremely low distortion and wide dynamic range, an element critical to realistic home cinema sound. The amplifier includes control connections that interface with the AV1, enabling sophisticated automatic control capabilities, and its ventilation design routes air from the rear and through the sides, rather than through the top of the amplifier, enabling it to be stacked directly on top of or underneath other components in an equipment rack to save installation space.
In January 2007, JBL will also introduce its BassQ Automatic Room Mode Correction (RMC) Processor, which can be added to any Performance Series system. The BassQ RMC processor is an innovative low-frequency-response-correction component that is used to achieve accurate in-room bass response. It connects to the AV1 and utilizes supplied measurement microphones and advanced DSP equalization to compensate for the peaks and dips in frequency response that are inherent in every room; the result is smooth, flat bass response with exceptionally realistic reproduction of movie soundtracks and music.
Pricing for JBL Performance Series systems ranges from approximately $10,000 to $30,000.
The Harman Consumer Group (HCG) is a leading designer, manufacturer and marketer of a wide range of high-fidelity loudspeakers, audio and video components, and multimedia systems for use in homes and automobiles, and with computers. The group’s brands include JBL, Infinity, Harman Kardon, Mark Levinson, Revel, Audioaccess and Lexicon.
HCG is a division of Harman International Industries, Incorporated. Harman International (www.harman.com)
is a leading manufacturer of high-quality, high-fidelity audio products and electronic systems for the automotive, consumer and professional markets. The company’s stock is traded on the New York Stock Exchange under the symbol “HAR.”
For additional information, contact:
Frank Doris
FM Group Public Relations
631-385-1304 ext. 402
frank.doris@fm-group.net
JBL, Harman International and Logic 7 are registered trademarks, and Performance, BassQ and Room Mode Correction (RMC) are trademarks, of Harman International Industries, Incorporated.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
