JBL Pulse 2 Bluetooth Speaker with Lightshow
The new JBL Pulse 2 is a wireless, splash-proof portable speaker that transforms any space into a party through a captivating light display. With sensational sound and synchronized flashes of vivid, full-color light, the 2nd-generation  Bluetooth speaker intensifies music anytime, anywhere. Listeners can wirelessly stream songs from any smart device and watch the glow of the Pulse 2 as it illuminates the room or evening sky to the rhythms of their favorite hits. To elevate and personalize the LED lightshow experience, the Pulse 2 features the JBL Prism color sensor lens. By pointing the lens at any desired color, the Pulse 2 will match the shade selected, amplifying the colors of life.
The Pulse 2’s high-quality stereo sound, splash proof design and 10 hours of playtime make it the perfect party companion. Pulse 2 also features a noise and echo cancelling speakerphone for crystal clear calls. Its JBL Connect technology can wirelessly link multiple JBL Connect-enabled speakers together to amplify the listening experience. For those looking for the pinnacle of personalization at the tip of their fingers, the JBL Connect app lets users further customize the lightshow and configure JBL Connect settings. Download the JBL Connect app to unlock even more interactive features waiting to be discovered on the JBL Pulse 2.
“Pulse 2 is the second generation of one of our best-selling portable products, and it will change the way people listen to music,” said Michael Mauser, president, Lifestyle Audio Division, HARMAN. “The flicker of vibrant lights in perfect synch with the music adds a new, mesmerizing dimension to the listening experience, and now we’re bringing the ability to personalize the lightshow that people absolutely love.”
Features
  • Wirelessly connect up to 3 smartphones or tablets to the speaker and take turns playing music with sensational sound
  • Built-in rechargeable Li-ion battery supports up to 10 hours of playtime with music and lightshow.
  • Take calls from your speaker with a touch of a button – crystal clear thanks to the noise and echo cancelling speakerphone
  • Customizable lightshow visualizes user’s favorite tracks or sets the atmosphere using its ambient lighting
  • Allows music lovers to use the speaker in the rain and the great outdoors with its rugged and splashproof design
  • Build your own ecosystem by connecting multiple JBL Connect enabled speakers together to amplify the listening experience
  • Provides a richer bass option with its dual external passive radiators
  • The JBL Prism color sensor lens enables users to add more colors to the palate by simply pointing and shooting the lens at the desired color and the Pulse 2 will adapt its lightshow to the shade chosen
  • Customize your lightshow experience and configure your JBL Connect settings, all at the tip of your fingers with the JBL Connect App
Pricing and Availability
The JBL Pulse 2 will be available globally in September 2015 for $199.95.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
