JBL’s PRX900 Series Portable Loudspeakers Will Make Your Next Family BBQ A Rocking Affair
The JBL PRX900 Series Powered Portable Speakers are a great solution for DJs, bands, music venues, rental facilities, and corporate A/V providers.
JBL PRX900 Series Loudspeakers on Stands
HARMAN Professional Solutions has announced the JBL PRX900 Series of portable loudspeakers and subwoofers. These speakers are targeted for use by DJs and bands as well as music venues, rental facilities, houses of worship, and corporate A/V providers
Tip: Although JBL refers to the PRX900 series as portable, they do need to be plugged into an AC power source to operate.
Designed for rugged indoor and outdoor use this product line features advanced acoustics, comprehensive DSP, enhanced power performance, and complete BLE (Bluetooth Low Energy) control via the JBL Pro Connect app (iOS, Android).
The PRX900 Series includes three powered two-way loudspeakers (PRX908, PRX912, PRX915) and two powered subwoofers (PRX915XLF, PRX918XLF). JBL has built these products from the ground up to include several advanced acoustic innovations.
The PRX900 series include proprietary drivers powered by Class D amplifiers designed to maintain clarity and definition even at maximum volume, along with improved dispersion and beam width and smooth low-frequency extension.
Control
JBL PRX900 Series Controls
For controls, the PRX900 Series incorporates an onboard system with an LCD display on the rear panel of the speakers and subwoofers, as well as control access through the JBL Pro Connect app.
Sound control options include
  • 12-band parametric EQ for system tuning and nuanced tonal control.
  • Soft system limiter with Soundcraft Overeasy option and speaker delay settings and presets.
  • The JBL Pro Connect app can control up to 10 speakers and can integrate with JBL EON ONE MK2, PRX ONE, and EON700 systems, and access app-only functions including speaker snapshots and grouping.
Construction
The PRX900 Series incorporates rigid composite cabinet construction with computer-modeled ribbing to enhance acoustic performance and durability. In addition, the subwoofers are housed in 18mm birch cabinets with strong bracing for deep low-frequency response.
To put it simply, the PRX900 series speakers are ready for the road if needed. These speakers are a great solution for DJs, bands, music venues,  and temporary rented facilities.
From Brandon Knudsen, HARMAN Professional Product Manager, Portable PA Loudspeakers: “For years, our PRX800 Series loudspeakers have been first-call systems for bands, DJs, installers, and houses of worship in large part thanks to their acoustic profile, their low-end extension, and their volume…“With the PRX900 Series, we’re taking things to the next level with next-gen acoustic innovations and an even brawnier power package to deliver clean, clear sound at any volume. Systems take advantage of the latest BLE technology and the JBL Pro Connect app ecosystem, for unrivaled control.”
JBL PRX900 Series Powered Speakers
JBL PRX908 Loudspeakers Front and Rear
JBL PRX908
SpecificationsPRX908PRX912PRX915
MSRP$849/each$999/each$1,099/each
Woofer 908G 8-inch ferrite magnet912G 12-inch ferrite magnet915G 15” ferrite magnet woofer
TweeterJBL 2408H-2 1.5” poly-annular diaphragm compression driver (horn)JBL 2408H-2 1.5″ poly-annular diaphragm compression driver (horn)JBL 2408H-2 1.5” poly-annular diaphragm compression driver (horn)
Frequency Response (-10b)67 Hz – 20 kHz50 Hz – 20 kHz48 Hz – 19 kHz
Frequency Response (-3b)65 Hz – 15 kHz65 Hz – 17 kHz60 Hz – 16 kHz
Coverage Pattern105° x 60°90° x 50°90° x 50°
Impedance (Woofer)4 ohms 4 ohms4 ohms
Impedance (Tweeter)8 ohms8 ohms8 ohms
Max SPL126 dB132 dB133 dB
Power Output2000W peak/1000W RMS2000W peak/1000W RMS2000W peak/1000W RMS
Crossover Frequency1930 Hz2050 Hz1920 Hz
Inputs2 Combo Inputs and 1 3.5 mm Stereo Jack2 Combo Inputs and 1 3.5 mm Stereo Jack2 Combo Inputs and 1 3.5 mm Stereo Jack
Outputs2 XLR Through Out and x1 Mix Out2 XLR Through Out and 1 Mix Out2 XLR Through Out and 1 Mix Out
CoolingNatural Convection/No FanNatural Convection/No FanNatural Convection/No Fan
Suspension/Mounting6x M10 Suspension Point and Pole Mount6x M10 Suspension Point and Pole Mount6x M10 Suspension Point and Pole Mount
Dimensions (HWD)479 x 312 x 285 mm (18.9 x 12.3 x 11.2 in)636 x 394 x 332 mm (25 x 15.5 x 13.1 in)717 x 465 x 383 mm (28.2 x 18.3 x 15.1 in)
Weight13.7 kg (30.2 lbs)19.5 kg (43 lbs)24.1 kg (53.1 lbs)
JBL PRX900 Series Powered Subwoofers
JBL PRX915XLF Subwoofer Front and Rear
JBL PRX915XLF
SpecificationsPRX915XLFPRX918XLF
MSRP$1,299$1,499
Driver915SG 15-inch ferrite magnet woofer918SG 18-inch ferrite magnet woofer
Frequency Response (-10b)36 Hz – 98 Hz30 Hz – 110 Hz
Frequency Response (-3b)40 Hz – 87 Hz35 Hz – 92 Hz
Coverage PatternOmnidirectionalOmnidirectional
Impedance 4 ohms4 ohms
Max SPL131 dB134dB
Crossover Frequency (Selectable)80 Hz, 100 Hz, 120 Hz80 Hz, 100 Hz, 120 Hz
Inputs2 Combo Inputs2 Combo Inputs
Outputs2 XLR Pass Through Outputs2 XLR Pass Through Outputs
Suspension/MountingPole Mount on Top SurfacePole Mount on Top Surface
Dimensions (HWD)549 x 480 x 580 mm (21.6 x 18.9 x 22.8 in)693 x 591 x 654 mm (27.3 x 23.3 x 25.7 in)
Weight28.6 kg (63 lbs)40.7 kg (89.7 lbs)
Pricing and Availability
The JBL PRX900 Series pricing and purchase options are available through JBL or Authorized Dealers
US Pricing / Global List
  • PRX908 – $849 / $1230
  • PRX912 – $999 / $1405
  • PRX915 –  $1099 / $1562
  • PRX915XLF – $1299 / $1718
  • PRX918XLF – $1499 / $1874
JBL Stage 2 & Stage XD Series Architectural Loudspeakers Unveiled: CEDIA 2022
JBL Synthesis SDA-1700 Subwoofer Amplifier: CEDIA 2022
JBL Classic Series Loudspeakers Are Now Back In Black: CEDIA 2022
CES 2022: JBL 4305P Studio Monitor Powered Bookshelf Loudspeakers
Sony SLS-1A Powered Line-Array Loudspeaker Unveiled
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
