JBL’s Extreme 4, Clip 5 and Go 4 Portable Bluetooth Speakers Promise Durability and Quality Sound Outdoors: CES 2024
JBL’s rugged portable speaker line gets upgraded to Bluetooth 5.3 with LE audio and Auracast in 2024.
JBL Xtreme 4, Clip 5 and Go 4 Portable Bluetooth Speakers for 2024
Portable audio has become a huge category for brands like Sony, Ultimate Ears, Klipsch and JBL. When you consider that JBL is owned by Samsung, it makes sense that the brand is focusing more of its attention on wireless headphones, earbuds, and portable loudspeakers that can work with both Android and iOS smartphones. The market for better quality portable loudspeakers is considerable and the new JBL Xtreme 4, JBL Clip 5, and JBL Go 4 offer something for everyone.
Emphasizing portability and sustainability, these new portables are made with recycled fabric and plastic.
All the speakers incorporate Bluetooth 5.3 with LE Audio and come in stylish colors.
From Dave Rogers, President, of Harman Lifestyle Division: “We have always been proud of our portable audio lineup at JBL and now that all three of these products are made with sustainable materials, we have even more to talk about. All the same features fans have come to expect but now built with the environment in mind,…Now customers on the go can find premium sound, stylish packaging, and environmentally conscious products all in one place with JBL!
JBL Xtreme 4 ($379.95)
JBL Xtreme 4 Portable Bluetooth Speakersfor 2024
The Xtreme 4 is the top entry in this group and incorporates several advanced features.
AI Sound Boost analyzes audio in real-time with an AI algorithm to optimize the acoustic output level, leading to more powerful and less distorted sound.
The JBL Xtreme 4 also now includes a replaceable battery for extended lifespan, Bluetooth 5.3 with LE audio, IP67 waterproof and dustproof, a multi-speaker connection when used in conjunction with Auracast, and a power bank providing 24 hours of playtime.
With its compact size, the JBL Xtreme 4 is at home for that intimate indoor or outdoor gathering.
JBL Clip 5 ($79.95)
JBL Clip 5 Portable Bluetooth Speaker for 2024
If the Xtrem 4 is more than you want to spend on a portable speaker, then the Clip 5 might be more your style.
For 2024, JBL has made the Clip 5 easier to travel with its redesigned carabiner. The carabiner has a larger,  more accessible opening. This makes the Clip 5 easier to clip on anywhere.
As a stylish travel accessory, the Clip 5 incorporates an increase in driver power that allows for more streamlined sound and consistent bass.
For additional flexibility, the Clip 5 features 12 hours of playtime, Bluetooth v5.3 with LE audio capabilities, and an IP67 waterproof and dustproof rating.
JBL Portable app support and multi-speaker connection via Auracast is also included.
JBL Go 4 ($49.95)
JBL Go 4 Portable Bluetooth Speaker
Despite its modest price and compact size, the Go 4 has a fuller sound and punchier bass than its predecessor.
As JBL’s smallest portable, the Go 4 is easy to take anywhere. This speaker features updated wider styling with a more durable strap.
JBL Go 4 provides 7 hours of playtime, is IP67 waterproof and dustproof, comes equipped with Bluetooth 5.3 with LE audio, and has a multi-speaker connection via the JBL Portable app and Auracast. The Go 4 comes in six colors.
Tip: The JBL Xtreme 4, JBL Clip 5, and JBL Go 4 will be available on JBL.com in June 2024
Comparison
ModelSpecsBattery Life Price
JBL Xtreme 4●IP67 Certified waterproof and dustproof
● Handy shoulder strap
● Made of recycled fabric and plastic
● AI SoundBoost
● Bluetooth 5.3 with LE audio
● Multi-speaker connection via Auracast™
● Powerbank
● Replaceable battery for enhanced serviceability
● Works with JBL Portable App
● Available in three colors
(Up to 6 hours longer when listening in Playtime Boost mode)
$379.95
JBL Clip 5● IP67 Certified waterproof and dustproof
● Works with JBL Portable app
● Available in six colors
12-hour battery life
(Up to 3 hours longer when listening in Playtime Boost mode)
$79.95
JBL Go 4● IP67 Certified waterproof and dustproof
7-hour battery life
(Up to 2 hours longer when listening in Playtime Boost mode)
$49.95
Tip: Additional details, including color options, are still forthcoming
Continue reading more stories from CES 2024.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
Ask an Expert
Waterproof vs. water resistant? Here's what the numbers really mean in those IP ratings.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
