Preview: JBL Shows Off Five MA Series A/V Receivers for 2024
JBL’s new line of A/V receivers are priced from $399 to $1,599. Which model is right for you?
JBL MA Series A/V Receivers for 2024
Soundbars have dominated the home theater category for a number of years and with consumers seemingly happy with fewer components and a relatively unobtrusive loudspeaker option that delivers an experience that is good enough for the asking price — it would appear that the traditional AVR has gone out of favour.
With only a few soundbars, however, like the Theory Audio Design 5.2.2 system delivering a world-class surround sound experience — it’s actually hard to make the argument that AVRs have become irrelevant.
The reality is that they are still the best option if you want the best possible immersive home theater audio listening experience. Some of the recognizable brand names in the AVR space include Denon, Marantz, Onkyo, Pioneer, and others, but for 2024, well-known speaker maker JBL has decided to reinvigorate its home theater emphasis with the introduction of the MA Series AVRs
JBL MA710 A/V Receiver
JBL MA Series Introduction
The JBL MA series AV receivers consist of five models based on a platform of fundamental connectivity with the latest features for video and music, with additional premium features as you move up in the line. The five models are:
  • MA310 (5.2 Channels)
  • MA510 (5.2 Channels)
  • MA710 (7.2 Channels)
  • MA7100HP (7.2 Channels)
  • MA9100HP (9.2 Channels)
Tip: MA stands for “Modern Audio” and these new components look nothing like JBL’s higher-end Classic Series. The new MA AVRs are designed to work with JBL’s new Stage 2 loudspeakers.
Gen Z Chimes in on JBL’s New Speakers and Receivers
All models feature similar technologies to support high-performance sound including Class D amplification to power all channels, Dolby and DTS decoding, and high-resolution 192kHz 24-bit DACs. With audio quality and a focus on ease of use, the MA Series models offer the flexibility of a wide range of input sources and listening modes so you can enjoy your content easily and quickly with the fewest number of steps.
The free EZ Set EQ app provides easy-to-use room equalization for optimized sound quality for all the AVR models in the MA line. The calibration gathers room acoustics data for each speaker group in under 2 minutes and can be done by anyone using an iOS or Android mobile device.
However, if you want more precise EQ, the MA7100HP and MA9100HP models additionally come with “Dirac Live Ready” for automatic room correction assuring audiophile-quality sonics, allowing integrators and power users to use advanced tools to optimize the system to their personal room acoustics.
JBL MA9100HP A/V Receiver
Shared Features
Channel Options: The MA series AVRs offer 5.2, 7.2 & 9.2-channel options that are designed to deliver top-notch performance in a home theater setup.
Easy Setup: Intuitive setup with a minimalist modern design
Audio Support: High-performance immersive surround sound with Dolby Atmos and DTS:X decoding, with support for up to 7.1.2 or 5.1.4 channel configurations (model dependent). Unlike many AVRs, the MA series models are designed to deliver great sound for both music and movies.
Video Compatibility: 4K & 8K video compatible.
Device Integration:  Seamless integration with smart TVs, gaming consoles, streaming, cable boxes, and more with 4 & 6 HDMI inputs and 1 & 2 outputs, plus eARC connectivity.
Bluetooth and Network Streaming: Stream music wirelessly via Bluetooth and network streaming (Apple Airplay 2, Google Chromecast).
Tech Note: The MA 310 provides Bluetooth, but does not provide network streaming.
On-screen setup and operation: On-screen display for easy system setup and operation (via HDMI).
Amplification: Five, Seven, and Nine channels of low noise Class D amplification for real-world power to all channels
EZ Set EQ: This feature provides easy-to-use room equalization for optimized sound quality.
Dirac Live: The MA7100HP and MA9100HP are Ready for Dirac Live room correction. However, you need to purchase a license to use it.
Comparison
JBL MA AVR Comparison
MA310MA510MA710MA7100HPMA9100HP
Price$399$599$799$1,199$1,599
Amplifier Type Class DClass DClass DClass DClass D
Number of Channels5.25.27.27.29.2
Power @ 8Ω 2ch driven60 Watts75 Watts110 Watts125 Watts140 Watts
Surround Sound Format SupportDigital Digital
DTS
Dolby Digital
DTS
Dolby Digital
DTS
Dolby Atmos
DTS:X
Dolby Digital
DTS
Dolby Atmos DTS:X
Dolby Digital
DTS
Dolby Atmos
DTS:X
HDMI In/Out4 / 14 / 16 / 16 / 26 / 2
HDMI VersionHDMI 2.0, HDCP 2.1 up to 4K/60Hz Ultra HDHDMI 2.1, HDCP 2.3 up to 8K/60Hz, 4K/120HzHDMI 2.1, HDCP 2.3 up to 8K/60Hz, 4K/120HzHDMI 2.1, HDCP 2.3 up to 8K/60Hz, 4K/120HzHDMI 2.1, HDCP 2.3 up to 8K/60Hz, 4K/120Hz
HDMI ARC/eARCARCARC/eARCARC/eARCARC/eARCARC/eARC
HDRYesYes  – HDR 10+, Dolby VisionYes  – HDR 10+, Dolby VisionYes  – HDR 10+, Dolby VisionYes  – HDR 10+, Dolby Vision
Pure DirectYesYesYesYesYes
Audio File FormatsMP3 / MPEG-4 AAC: up to  48 kHz / 320kbps
WMA: up to 48 kHz / 192kbps
ALAC: up to 192 kHz / 24-bit
FLAC: up to 192 kHz / 24-bit
PCM / WAV / AIFF: up to192 kHz / 24-bit
DAC192kHz/24-bit192kHz/24-bit192kHz/24-bit192kHz/24-bit192kHz/24-bit
EZ Set EQYesYesYesYesYes
Dirac Live ReadyYes – License Purchase Required for useYes – License Purchase Required for use
Light ShowYesYes
Wi-FiYes (2.4/5GHz)Yes (2.4/5GHz)Yes (2.4/5GHz)Yes (2.4/5GHz)
Bluetooth ReceiveYes (v5.1, Low  Energy)Yes (v4.1, Low  Energy)Yes (v5.3, Low Energy, APTX HD, APTX Adaptive)Yes (v5.3, Low Energy, APTX HD, APTX Adaptive)Yes (v5.3, Low Energy, APTX HD, APTX Adaptive)
Apple Airplay 2YesYesYesYes
Chromecast Built-inYesYesYesYes
Digital Audio Inputs1 Coax
1 Optical
1 Coax
1 Optical
1 Coax
1 Optical
1 Coax
1 Optical
1 Coax
1 Optical
Stereo Analog Input2 x RCA2 x RCA2 x RCA2 x RCA2 x RCA
Phono Input (MM)YesYesYes
Pre-Out (Single End RCA)2 x Subwoofer 2 x Subwoofer 2 x Subwoofer 2 x Subwoofer2 x Subwoofer
Dimensions (HWD) – includes feet4.3 x 17.0 x 13.7”
109.2 x 432. x 347.6mm
4.3 x 17.0 x 13.7”
4.3 x 17.0 x 13.7”
5.3 x 17.0 x 15.6”
135.0 x 432 x 396.4mm
5.3 x 17.0 x 15.6”
Weight11.3 lbs
(5.1kg)
12 lbs
(5.4kg)
13.8 lbs
(6.3kg)
16.4 lbs
(7.4kg)
16.8 lbs
(7.6kg)
What’s in the BoxJBL MA310
1x IR Remote
2x AAA batteries
1x Bluetooth antenna
1x Power Cord
1x Quick-Start Guide
1x Safety Sheet
JBL MA510
1x IR Remote
2x AAA batteries
1x Power Cord
1x Safety Sheet
1x Wi-Fi antenna
JBL MA710
1x IR Remote
2x AAA batteries
1x Power Cord
1x Safety Sheet
2x Wi-Fi antenna
JBL MA7100HP
1x IR Remote
2x AAA batteries
1x Power Cord
1x Safety Sheet
2x Wi-Fi antenna
JBL MA9100HP
1x IR Remote
2x AAA batteries
1x Power Cord
1x Safety Sheet
2x Wi-Fi antenna
Initial Impressions
As stated at the top of this article soundbars dominate as the primary home theater solution for most consumers, and even JBL offers up a soundbar line. However, for those looking for a home theater experience that offers up a lot of connectivity, control, and power, the AVR is still the way to go.
The JBL MA series A/V receivers appear to provide practical solutions (reference the comparison chart) at reasonable price points. Ultimately, AVRs need to be paired with loudspeakers, and JBL’s new Stage 2 loudspeakers are specifically designed in matching white or black finishes for a cohesive look with modern appeal.
Pricing & Availability
The JBL MA Series AV Receivers are priced as follows:
They can be purchased through authorized JBL Dealers and other approved outlets.
Related Reading
2 Comments
2 Comments
  1. ORT
    July 19, 2024 at 11:45 am
    They need to lose that Valley Girl spokesbot. Talk about awful vocal inflections? “I’m all”…
    I’m out.
    ORT
    • Chris Boylan
      July 19, 2024 at 6:38 pm
      I expect this to be the reaction of most of our readers as most of our readers are of a different generation (myself included). I was at first mildly horrified when I watched the video clip, but then my marketing background kicked in and I realized that taking an approach like this is exactly the kind of thing that HiFi manufacturers need to do in order to attract a new demographic. With this being JBL’s return to the “direct” consumer market for receivers (their previous models were only available in the CI market), they’re entering a very crowded market – Denon, Onkyo, Pioneer, Sony, Yamaha, etc. The market isn’t growing so really the only way a new player will be able to succeed will be by expanding the potential market.
      The question is can they do this without pissing off too many of their previous customers? That remains to be seen. But personally I’m impressed that they were willing to take the risk. As a father of a teenage daughter and son, I have to say they totally nailed it. 🙂
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
The Anthem MRX SLM delivers high-end performance in an ultra-slim AVR built for CI installs and small rooms, though limited power and inputs may...
At $329, JBL’s Tour PRO 3 wireless earbuds combine dual drivers, adaptive noise cancellation, LDAC support, and a touchscreen Smart Charging Case to challenge...
Phil Jones from Harman reveals what makes Denon and Marantz A/V receivers unique to help you decide which model is right for your home...
Compare Denon and Marantz AVRs for 2025—explore features, performance, and prices to find the best home theater receiver for your setup, from budget to...
JBL unveils its new flagship 4369 Studio Monitors at the Tokyo International Audio Show for audiophiles and studios alike. Available Q1 2026, price TBA.
After three days roaming the hallowed halls of CEDIA Expo 2025, here are our picks for "Best in Show" for home theater systems.
