JBL L42ms Integrated Music System Introduced at Audio Advice Live
The JBL L42ms is an all-in-one wireless music system for $999 that is the smaller and less expensive version of the L75ms.
jbl-l42ms-music-system-lifestyle-black
Audio Advice Live is happening this weekend in Raleigh, North Carolina, and one of the first new product introductions on Friday from Harman Luxury Audio Group was their new JBL L42ms Integrated Music System.
Building on the foundation of JBL’s L75ms Integrated Music System that was introduced in 2021, the L42ms Integrated Music system is a more modest version that’s reduced by 7-inches across. Although both speakers maintain the same look when the waffle grille is on, there are some differences that help the L42ms shave $500 off the price.
JBL L42ms Integrated Music System in Black and Walnut Finishes
Tip: The curved front design supports a wider soundfield. However, this speaker is not a soundbar.
Speakers and Amplifiers
The L42ms incorporates a 4-driver speaker design with dual 4-inch woofers and dual .75-inch Aluminum tweeters. The frequency response of the speaker system is stated by JBL to be 55 Hz to 25 kHz (-6 dB).
The speakers are supported by separate amplifiers for the woofers (75 watts RMS per woofer) and tweeters (25 watts RMS per tweeter).
Music Playback System
The music playback system features include:
Tip: If you want to connect a turntable, the turntable needs to have a built-in phono preamp or you need to place an external preamp between the turntable and the L42ms via its RCA line inputs.
JBL L42ms Integrated Music System Rear Panel Connections
In addition to traditional volume and bass/treble control, there is a built-in selectable Soundfield Expander (SFX) and a Bass Contour On/Off setting.
The L42ms features built-in access to Spotify Connect and Tidal Connect streaming services.
Users can also access music on compatible UPnP network storage devices on a local network or a USB drive connected via the USB-A input on the back of the L42ms.
Remote Control and App for JBL L42ms Integrated Music System
The free JBL Premium Audio App provides an easy connection to a Wi-Fi network. After setup, the app makes additional streaming audio services available including Amazon Music and Qobuz, plus it provides access to internet radio and podcasts.
The L42ms can be controlled by the JBL Premium Audio app or the provided Bluetooth hand-held remote. Input selection and volume controls are also provided on the top panel of the system.
Two Bonus Features
Roon Ready: This allows users to access their library of music at the highest possible resolutions supported by the L42ms.
Works with Smart Things: This integrates the L42ms into the Smart Things ecosystem, which includes over a billion Galaxy devices and Samsung televisions and appliances for one-touch operation and functionality. (Additional Smart Things hardware is required.)
JBL L42ms Integrated Music System in walnut with grill off.
JBL L42ms
Comparison
L42msL75ms
MSRP$999.99$1,500
TypeCompact Integrated Music SystemStreaming tabletop loudspeaker system
Low Frequency DriversDual 4-inch (100mm) Pure Pulp white cone woofersDual 5.25″ (133mm) Pure Pulp cone woofers
High Frequency DriversDual 0.75-inch (20mm) Aluminum dome tweeters with waveguidesDual 1″ (25mm) Aluminum dome tweeters with waveguides
Midrange Driver4″ (100mm) Pure pulp cone midrange
Amplifier Power75W RMS per woofer125W RMS per woofer
25W RMS per tweeter25W RMS per tweeter
50W RMS for center
Sound ControlsSpeaker placement compensation, selectable sound-field expanderSpeaker placement compensation, selectable sound-field expander
Wireless InputsWiFi streaming, Bluetooth 4.2WiFi streaming, Bluetooth 4.2
Wired InputsEthernetEthernet
HDMI-ARCHDMI-ARC
Phono (MM)
Line in (RCA)
3.5mm3.5mm
ResolutionUp to 24-bit, 96kHzUp to 32-bit, 192kHz
Frequency Response55Hz – 25kHz (-6dB)45Hz – 25kHz (-6dB)
Maximum SPL102dB @ 1m106dB @ 1m
Subwoofer OutputAutosensing w/ Auto-engage of 80Hz High Pass Filter2V RMS with auto-sense/engage HPF
EnclosureFront-ported tabletop in satin walnut furniture-grade wood veneerFront-ported tabletop in satin walnut furniture-grade wood veneer
GrilleBlack foam Quadrex grilleBlack foam Quadrex grille
Dimensions with grille
(HxWxD)
6.4″ x 24.3″ x 9.2″
(162mm x 617mm x 234mm)
8.5″ x 31.1″ x 11.3″
(216mm x 790mm x 287mm)
Remote Control TypeBTLEBTLE
Product Weight (Each)26.3 lbs. (11.9kg)35 lbs. (15.9kg)
Shipping Weight34.3 lbs (15.6 kg)44 lbs. (20.0kg)
Warranty5 Years5 Years
Availability and Pricing
More information is available on the Official JBL L42ms Product Page. The 42ms will become available in the fall of 2023 (in time for the Holidays) for $999.99.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
An immersive and dynamic listening experience, with a bold omni-directional design that creates a spacious, all-encompassing soundstage.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
