JBL Cinema 500 Home Theater Speaker System
Harman announced the JBL Cinema 500, a 5.1 home theater speaker system with a dual-midrange center, four satellite speakers and a down-firing, 150-watt 8-inch (200mm) powered subwoofer.
The four identical satellites are voice-matched to the center for consistent sound from speaker to speaker, creating a more realistic 360-degree surround-sound field throughout the room. The Cinema 500 employ two PolyPlas cones in the center channel with a lower crossover point in the surrounding satellite speakers that have dual 3-inch (75mm) PolyPlas.
Cinema 500 System Technical Specifications
Frequency Response: 32Hz – 20kHz (-6dB)
Cinema 500 Satellite Speakers:
  • Low-Frequency Transducers: Dual 3″ (75mm) PolyPlas cones, video-shielded
  • High-Frequency Transducer: 1″ (25mm) titanium-laminate dome, video-shielded
  • Recommended Amplifier
  • Power Handling: 100 watts
  • Nominal Impedance: 8 ohms
  • Sensitivity (2.83V/1m): 89dB
  • Crossover Frequency: 3.7kHz
  • Enclosure Type: Sealed
  • Connector Type: Push-spring terminal
  • Dimensions — including stands: (H x W x D): 11-3/8″ x 4-3/4″ x 3-3/8″ (289mm x 121mm x 86mm)
Cinema 500 Center Speaker:
  • Recommended Power Handling: 100 watts
  • Dimensions — including stand: (H x W x D): 4-7/8″ x 12″ x 3-3/8″ (124mm x 305mm x 86mm)
Sub 140P Subwoofer:
  • Low-Frequency Transducers: 8″ down-firing cone
  • Enclosure Type: Ported (down-firing)
  • Amplifier Power: 150 watts
  • Frequency Response: 32Hz — 150Hz (–6dB)
  • Crossover Frequency: 50Hz — 200Hz (variable)
  • Controls: Volume, crossover frequency, phase
  • Connections: Left and right RCA line-level inputs, LFE input
  • Power Requirement: 120V/60Hz, 150W (US); 220V/60Hz, 150W (EU)
  • Power Consumption: <1W (8mA@120V) standby; 300W (2.5A@120V) peak
  • Dimensions (W x H x D): 19″ x 14″ x 14″ (475mm x 355mm x 355mm)
Pricing and Availability
The JBL Cinema 500 system is available for $699.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
