Earbuds & In-Ear Headphones
Jays a-JAYS One In-Ear Headphones Announced
JAYS announced the a-JAYS One+ Android optimized in-ear headphones, offering a 8.6mm dynamic speaker, tangle-free flat cables, a remote with built-in microphone and an L-shaped connector. Out of the box, the remote and mic allow you to pick up and hang up calls and play or pause your music, plus they are compatible with your local music library, Skype and iChat, as well as music and video content streamed to your phone via apps like Spotify and YouTube. JAYS specially developed, complimentary JAYS Headset Control App for Android allows you to discover even more features, turning your a-JAYS One+ into a fully customized multi-feature control. The a-JAYS One+ is optimized for Android devices, but also works with any smartphone.
JAYS’ specially developed Android app, called JAYS Headset Control, adds even more features to your a-JAYS One+ headphones when using them with an Android device. The app turns the a-JAYS One+ into a fully customized, multi-feature control that allows you to change volume, skip songs, apply voice control and more. The free app can be downloaded directly to your Android device from Google Play. Simply search for JAYS in the Android app store on your device, install the app and you’re ready to customize your headset.
For further customization of the headphones, the a-JAYS One+ comes with five pairs of silicone sleeves ranging in size from XXS to L. This choice means all a-JAYS users can achieve a natural, comfortable fit, and maximum external sound insulation. The included gift box packaging can be used to store the silicone sleeves when not in use or to protect them when on the go. Additionally, the a-JAYS One+ deliver a rich, deep bass response while uplifting and reinvigorating the rhythm sections of songs to create a spectacular sound experience.
Jays a-JAYS One+ In-Ear Headphones - Black
Specifications
Driver
  • Type: 8.6 mm Dynamic Speaker
  • Sensitivity: 95dB @ 1kHz
  • Impedance: 16 Ohm @ 1kHz
  • Frequency Response: 20 Hz — 18 000 Hz
Earphones
  • Finish: Matte
  • Isolation: -40dB @ 2kHz
  • Size: (L)18.3 x (W)11.8 x (H)13.8 mm
  • Weight: 14 grams (0.49 oz)
Cord
  • Type: TPE coated flat tangle free cable
  • Size: Width 5mm / Thickness 1.2mm
  • Length: 115 cm (45 in)
Plug
  • L-shaped, Silver-Plated Stereo Plug 3.5mm (1/8 in)
Remote
  • Controls: 1 button remote
  • Mic: Yes
Price and Availability
The a-JAYS One+ is available now in black or new white color for $59.99.
Campfire Audio Alien Brain IEMs Front and Back
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
