Jaybird RUN True Wireless Sport Headphones for Runners
Jaybird announced wire-free earphones for runners called the RUN True Wireless Sport Headphones. For $180 they provide a secure, run-specific comfort-fit, sweat proofing, water resistance and skip-free customizable sound. It’s all packed in a beautifully designed, wire-free, lightweight and compact form factor.
Jaybird RUN features the latest in true wireless Bluetooth technology, offering big, rich sound with drop-free connectivity in a stylish, low-profile design. Jaybird RUN comes with a selection of interchangeable tips and fins for different ear sizes, so you’re sure to get the perfect secure and comfortable fit. And its double hydrophobic nano coating protects your headphones from sweat and water damage. One intuitive control-button takes calls, starts and stops music, skips tracks and activates Siri or Google Assistant. It’s even designed for one-ear use, so runners can listen while staying aware of their surroundings.
With Jaybird RUN, you customize the sound signature with the free Jaybird App by adjusting the lows, mids and highs for a truly personalized music experience. The Jaybird App can also help you locate your headphones with the Find My Buds feature, in case they go missing. The app even allows you to share Spotify running-themed playlists with the Jaybird community.
Jaybird says you will get four hours of music on a single charge, and the pocket-sized charging case provides an additional eight hours, for a total of 12 hours of portable battery life. A quick, five-minute charge gives you one hour of play time, so you never have to hit the trail or pavement without your music.
Price and Availability
Jaybird RUN True Wireless Sport Headphones will be available in October 17, 2017 for $179.99 in two colors: Drift (white with silver metal accents) and Jet (black with silver metal accents). Both can be pre-ordered now.
For $30 less and those with smaller ears that require a finicky fit, Jaybird also released FREEDOM 2 with SpeedFit headphones that are lightweight, sweat-proof and water resistant. They are still wireless, but include a cord that wraps around your neck for greater comfort, along with softer and more flexible tips for an improved fit.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
Do the Bowers & Wilkins Pi7 S2 True Wireless Earbuds deliver the outstanding performance of their larger on-ear siblings?
At $219, Beyerdynamic's first open-ear true wireless earphones aim to promote situational awareness without sacrificing sonic performance.
The Bowers & Wilkins Pi5 S2 offer a number of improvements over their predecessor including better ANC performance and battery life.
At $299, Astell&Kern's second generation true wireless earphones are among the best available for those seeking a neutral sound signature.
New 2nd generation Astell&Kern true wireless earphones offer a few upgrades, while keeping its $299 price tag the same.
Can the $100 FiiO FW3 TWS Earbuds dominate the entry-level category? Based on their recent track record, these might be ones to consider below...
