Jaton Will Launch the High-Performance Amplifier, Pre-Amp Receiver & 1080P 3LCoS Projector at CES 2007
Jaton will launch the new class A high-performance power amplifier Operetta series,RC7000P 7.1 channel surround sound pre-amp receiver and 1080P 3LCoS Porjector at Las Vegas, CES 2007 High Performance Audio Exhibition section. The introducing product line presents a guarantee on superior sound, rich experience, and reliable performance.
Operetta Amplifier
The Operetta amplifier is designed in 3 different models: 140 Watts x 5 Channel, 300 Watts x 2 Channel, and 500 Watts Mono.
The best design feature of Operetta is the signal processing and the noise reduction. Its special filter circle eliminates almost 100% of noise and gives users crystal-clear audio experience.
The “Maximum Input Level” AP testing graphic below shows that the THD level is below 70 dB when input signal goes up to 5 V rms @ 1 Watts, 8 Ohm output setting. This means you don’t hear any noise from your speakers after you turn the volume to maximum and pause the music playing.
RC7000P Pre-Amp Receiver
The RC7000P pre-amp receiver decodes the digital PCM 24 bits audio input signal to a 7.1 surround sound output. It also can be changed to 3 x stereo to connect to 3 different rooms. The front panel design is clean and classic and well arranged for simple usage.
The built-in a + 6 dB video signal enhancement is another superior feature of the RC7000P pre-amp receiver. It outputs a progressive picture even for long-distance connection. For achieving the prefect audio setting with an ease of use, the channel audio delay and volume control are designed as individual components for the AV integrator. The 5 equalizer modes offer users various options to experience their favorite fever music.
HD900 1080P 3 LCoS Projector
The HD900 displays professional film-like images to the best. It is equipped with state-of-art video processing Silicon Optix HQV Realta chip. with full High-Definition 1920 x 1080 progressive resolution 3 LCoS micro-display.
Its superior color balance with 6000:1 Native Contrast Ratio reproduces ultra high contrast and vivid details of natural tones and textures.
Company Website: www.jaton.com
Jaton Corporation
Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Wattson Audio Madison Power Amplifier Front Wattson Audio Madison Power Amplifier Front
Discover the new Madison Power Amplifier from Wattson Audio — a Swiss-engineered Class A/B amp delivering rich harmonics, ultra-low distortion, and dynamic performance in...
WiiM Voice Remote 2 with components lifestyle WiiM Voice Remote 2 with components lifestyle
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
Sharp TIVO TV Lifestyle Man View Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
