IsoTek EVO3 Solus Power Conditioner
IsoTek announced the EVO3 Solus power conditioner for hi-fi audio systems replacing their GII Solus model.
Positioned between the entry-level Sirius and highly acclaimed Aquarius in IsoTek’s range, the EVO3 Solus builds upon the design of the outgoing GII Solus by incorporating a number of technologies trickled down from the company’s top-end power conditioning units. Up to six audio components may be connected, delivering a cost-effective way to significantly upgrade the sound quality of every source and amp component in a hi-fi system.
Mains noise can be broken down into two types. The first is differential noise, which is typically caused by switching — everything from a light switch to the switch-mode power supplies used in common domestic appliances. The second is common mode noise, which emanates from a point source, such as a radio transmitter. These noise types are complete opposites, yet they exist side by side and arrive in the home via live and neutral mains cables.
IsoTek has enhanced a number of key circuits to ensure the EVO3 Solus tackles both differential and common mode noise with even greater effectiveness than the GII model it replaces. The sophisticated delta filter network has been significantly improved, while newly devised individual differential filtering is applied to each of the unit’s six outputs, preventing cross-contamination between connected audio components.
IsoTek’s proprietary KERP and Polaris-X technologies are also integrated into the design. KERP (Kirchoff’s Equal Resistance Path) equalises resistance across all outlets, thereby increasing the effectiveness of the internal filter networks. Polaris-X ensures that the electrons take the easiest route, thus reducing crosstalk and improving component-from-component isolation.
In addition to improved filtering, the EVO3 Solus delivers greater protection against spikes and surges in the mains supply, with 22,500A of instantaneous, repeatable protection on tap. In contrast to inferior designs, a full 10 amps of current can be drawn at any time, delivering power of up 2300VA with unrestricted transient ability — this is especially important for power amplifiers. Silver-plated oxygen-free copper wiring is used throughout, while the unit’s sturdy rack-width aluminium casing ensures it is built to last.
The system diagram below illustrates the various processes as electricity travels from a wall socket through the EVO3 Solus, to each of the six individually filtered outlets.
IsoTek Diagram
“The EVO3 Solus is a practical, high-value accessory that improves the sound quality of all audio systems without the dynamic constraints imposed by lesser power conditioners,” says Keith Martin, founder and managing director of IsoTek. “It delivers class leading protection against dangerous power surges and spikes, and supplies clean power to all connected equipment. Our enhanced individual differential filtering system, developed specifically for the EVO3 Solus, eradicates the possibility of cross-contamination between components, which can spread noise throughout an audio system — an issue that’s often overlooked in the elimination of differential mains noise. This is, quite simply, the most sophisticated power conditioner available at this price level — in terms of improving sound quality, there’s nothing to touch it.”
Specifications
  • Number of Outlets: 6
  • Type of Outlets: UK, EU, US, CH, AU, ZA
  • Mains Inlet: IEC C14 Fused
  • Mains Voltage: 100-240VA / 50-60Hz
  • Maximum Current: 10 amps HRC
  • Total Power: 2300V A
  • Dimensions: 445x85x305mm (WxHxD)
  • Weight: 7.5kg
Price and Availability
The EVO3 Solus will be available October 2011 in black or aluminum for £595.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
